motorcraft solenoid 3 terminal vs 4 terminal - Ford Truck Enthusiasts Forums
Old 12-16-2012, 11:14 PM
RockWVU RockWVU is offline
RockWVU is starting off with a positive reputation.
I needed a new starter solenoid for my 1986 f350 460 with elec pumps.
Ford dealer said they had one in stock. I took old one off and start to install the new one.
New one only has one small termminal whereas the old one had two.
The missing one is where the blue wire would go. I think this is for the electric pumps. Is there a way to make this work or do i need to return the part?
The look the same other wise. Two big terminals stacked vertically and the small ones would be on either side of those. The new one just has a "blank" spot on the right side where blue would go.
Thanks
Old 12-17-2012, 12:57 AM
Swatter's Avatar
Swatter Swatter is offline
Swatter is starting off with a positive reputation.
The missing "I (Ignition)" terminal sends 12v to the coil when cranking. The coil runs on 7-9 volts but needs 12v when cranking.
I'd think you want to return it for the 4th terminal.
Old 12-17-2012, 09:03 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
You are correct, you need the 4th terminal on your truck for the fuel pump system. It's what primes the system by powering the pumps during cranking. After that, the pumps get their power through the oil pressure switch/relay system. It's the wire in the picture below that goes straight down from the starter relay to the fusible link.
PAINLESS WIRING HARNESS IN 55 F350 mgerdau 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-29-2016 12:17 AM
Truck still running with key in hand NuMex75 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-31-2014 03:26 PM
92 Bronco 302 Won't Start gaxlt Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 07-10-2013 10:56 PM
2 gauge battery charge cable and alternator pigtail write up strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 32 06-12-2013 01:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
