05 Escape 3.0L Hard Start/Rough Idle - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 12-16-2012, 09:59 PM
DieselHardware's Avatar
DieselHardware DieselHardware is offline
DieselHardware is a name known to allDieselHardware is a name known to allDieselHardware is a name known to allDieselHardware is a name known to allDieselHardware is a name known to allDieselHardware is a name known to all
Been a long time since I've messed around in the gas world since I drive a 7.3L Powerstroke, but my wife has an 05 Escape. It was running great all weekend until after I filled up in Vegas to head home. I'm guessing the fillup is just coincidence. On the way home, first place we pulled off, the engine was running rough at idle. It is worse when in gear and under load than it is in neutral. Comes off of idle fine, no hesitation, or lack of power. After stopping a couple times on the way home, it is taking longer and longer to start each time we start it. Seems to be running rich and smell of raw gas in the car. Sounds to me from research tonight that it might be a coil pack. Any thoughts? Going to hookup the computer tomorrow and scan it after I get home.
I have also checked the access cover for the fuel pump and no leaks around there, cleaned the IAC since it was quick and simple and no change. Haven't touched the MAF sensor yet.
Old 12-16-2012, 10:22 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Checking for codes at this time will be essential.
Could be coil related misfires or MAF issues.
Do a primary check for air leaks, vacuum leaks, loose fittings, oil cap.
Old 12-17-2012, 09:18 PM
Appears to be an EGR valve, but I have attached the report from AE. Please let me know if you have any info.
Old 12-17-2012, 11:55 PM
Checked the DPEF and at idle had 5.6 volts. Pulled the EGR and did a quick clean as good as I could. Got it put back on, cleared the CEL and seems to be purring like a kitten right now. Any good way to clean the EGR or better off just buying a new one since this one has 102k on it?
Old 12-18-2012, 12:21 AM
khadma's Avatar
Carpenter Local 745
Is the P0300 and P0316 gone too?
You may have cleaned the EGR valve well enough.
Old 12-18-2012, 08:47 AM
Haven't had a chance to take it for a drive just yet. After cleaning it, I cleared the CEL and it started right up and no missing at idle. DEPF showed 1.05v at idle instead of the 5.6v it was showing before cleaning the EGR. Wife is going to drive it today and see how it does. Seems to have cured the issue.
Old 02-06-2013, 06:49 PM
Krataxx Krataxx is offline
Krataxx is starting off with a positive reputation.
The other day wife put fuel in her mazda before class. On her way home, everytime she came to a stop the tribute would sputter and idle rough. It drives just fine above 1500 rpm.
When I went to start it. It took a long time to fire. I had to push the gas petal down to get it to fire. Once it was running the idle was rough, and at time I thought would die. I could smell fuel from the exhast.
I have replaced both the upper and lower intake gaskets. Replace the IAC. Nothing has worked. I checked for leaks using a carb cleaner on the fittings. I think. I heard a hiss somewhere behind the intake, near the firewall. But, I have not found where that could be coming from.
Anyone have any suggestions?
Engine Lost Power, Then Kept Stalling at Idle Clem's Cousin 1968-2013 Full Size Vans 2 08-24-2016 02:01 PM
Rough idle after warm up and engine cutting out when driving. Please help! ET3RNAL 1967 - 1972 F-100 & Larger F-Series Trucks 8 02-09-2016 08:44 PM
96 7.3 need help!!! 63ferd 1994.5 - 1997 7.3L Power Stroke Diesel 2 07-19-2014 09:08 PM
Tips if your having rough idle when cold scottss80 Escape & Escape Hybrid 10 02-07-2013 08:29 AM
Code PF3334? BossEliminator 6.0L Power Stroke Diesel 2 04-21-2010 11:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
