My Project Truck.
#121
I found a fuel leak. But it's not coming up top. Nothing is leaking up there.. It's coming from the bottom of the engine somewhere. It was coming from the Flywheel inspection cover. I took it off, It was coming from up from behind the flywheel by the passenger side. The flywheel isn't wet.. It only happens after I had been cranking. It really pours out.. I'm thinking a seal of some kind.
Red arrow points to where I think I saw it coming from.
#125
Thanks for the picture, yes, it's fuel. Some had stayed in the inspection cover when i took it off. Smell, color was a bit off, but it had a bluish tint to it. And it has stained the parking lot underneath it.
#126
#127
#128
#129
Ok sorry for the big picture. I resized it on my computer but I guess image upload doesn't care?
Anyway: I was going through old pictures on my phone and I stumbled across a few things. Is this the "Grey" that everyone refers to? I have not seen this one in any pictures of y'alls CPS. It did come with shims, but I didn't realize they were to adjust the air gap.
I also found a video of my no-start when I was cranking. My phone will only let me send 10* seconds of it, so once it's uploaded to youtube, I'll post the link. The RPM show about 100 when cranking, no popping and oil pressure gauge goes to the middle a few seconds into cranking.
Link to video, sorry it's short. My phone really doesn't like youtube for some reason right now or you would hear me explaining what I did.
I'm pretty sure that this CPS might be my current problem, or at least one of them. I could start a new thread, but I figured I would just add it to this one.
#130
#131
Maybe. I saw the "blue" on Diesel-orings, and will pick up that one, but it's too easy to get a ford one when I get back. The funny thing, is that was my spare, the black one fell apart when I took it out.
#133
#134
John, you might wanna also check and see if there is an International house near you. I got mine form their last year and it is still working great 57k miles later. The black one came out, which I kept for spare. Just check and see which one might be cheaper, but either one will be the one you want.
#135
I was trying to find what the PN for that one was. I got in on Ebay, IIRC it was IH, but was something about advanced timing or something in the item description. It came with the shims, but not knowing what they were for ended up in my spare parts bin. It could be the right sensor, just not air gapped.
I'm hoping that's all it is right now. I'll pick up a couple, and just try them out. Get an IH one, ford, and the blue. At least I'll have plenty of spares I know will work!
Byron, I'll do a search and see what I can find. I'll be heading to MO to Northern auto parts, to pick up the bearings and some tools once everything is apart. So I'll check there too. I'm not sure what my cam, crank and mains are going to be, or if they'll need machined at all, so I don't want to order a kit online with standards, and need to get over/undersize bearings. It's just easier, and cheaper, to make a day of it and get the right stuff all at once! I'll probably order the gaskets and pistons from Clay, he has a few other things I wanted to get anyway.
In other news, might be working on my truck sooner than I thought I would be! Nothing set in stone, but it's something to be hopeful for!
