99 350 sd need help
99 350 sd need help
Thanks for getting back,
How would i know if I have the snow plow option?
where on the sticker. could you send me a pic of yours. Maybe I could figure out what the rest of mine says if I knew where to look. The right rear is broke. the over and under is fine its the center main leaf the bottom two leafs in the rear are gone.
Oh the truck was used for plowing
thanks
thanks
99 350 sd need help
Any parts store should be able to get rear leaf springs. Change both as a pair. Most 4x4 shops install lift kits and some come with leaf springs included. Those same kits are generally available for 2WD models. Check in an offroad truck magazine for prices. To buy springs you need the code and options if you are going to the dealer. But aftermarket sources allow you to increase your payload, change ride height, and firm or soften your truck's ride. My F250 and F350 both have soften and weakened with years of hard work. My advice is check around and decide if you want same as new springs or better. You have to know weight rating, # springs, width, length and shackle size (width, size of bolt-diameter & length).
