Horrible starter grinding noise 79 F250
I recently purchased a 1979 F250 with a 351m engine it had not been started in about 3 years. We knew it needed a new flywheel because when we cranked on it the starter just made a horrid grinding noise and would slip off the flywheel and not start. Now we just got in back together with all new clutch, milled and new ring gear fly wheel. When i go to start it it makes the same horrid noise as before but does start up. I thought maybe it was the wrong starter so i got a new one but it is making the same noise also. Is this just how these trucks sound or what else could it be as im at a complete loss as to what it could be
Thanks for all help
Thanks for all help
Otherwise, hard to say as I can't listen to it.
Could be a mesh problem. Maybe starter needs some shims?
Not to sound like an a$$, but if the starter and flywheel were meshing correctly you wouldn't have the grinding noise.
Here are some additional thoughts. Some may seem obvious, you may have already addressed them, but on the off chance you haven't...
I know you replaced the starter but the replacement might be at fault.
Are you sure your new starter is for a 351M and not a 351 Windsor?
As I remember (I think) some Ford V-8's used two different starter noses, one for a stick and one for the automatic. I'm not sure if the 351M did. They allowed the starter drive to go "deeper" into the bell housing. The wrong nose could allow the starter drive (Bendix) to hit the flywheel. You can check this by pukking the starter and looking at the rear face of the Bendix. If there is flywheel contact you will see "swirley" marks on this face.
Is the bell housing properly located by the two dowell pins?
Is the block plate in place between the bell housing and the block? The block plate locates the starter.
Hope one of these helps.
Roger Carter
Roger Carter
It happens that a bad one get's shipped on occasion, no matter the supplier. Wouldn't hurt to double check the part number of the one you used even.
351 W (6 valve cover bolts) did have different starter noses between Auto and Manual as pointed out above ...
... while 351M (8 valve cover bolts) did not as far as I can recall.
I don't think the 351W was available in trucks in 1979 was it?
i think i know the same sound happened to me my problem was at one point the starter came loose if it is not meshing you will see by looking at the teeth on the ring gear weather they're chewed up or not if this is so dont turn it over unless you want to put another ring gear on it although they are strait teeth on those you should be able to flip it over and use the other side of the ring gear. But anyhow take flash light and look in the starter hole if the ring gear is not chewed up then thats not the problem but chances are it is.
RockAuto Parts Catalog
Might confirm that you are on the right track or not?
Aridecommando
23
12-16-2015 12:34 PM
dustydogg31
08-28-2015 11:20 AM
lemasters f100
04-12-2014 02:37 PM
pit_of_pity
12-15-2010 07:26 AM
Mikes67F250
12-21-2005 12:34 PM
