Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-16-2012, 06:09 PM
58f350guy 58f350guy is offline
Garage is empty, add now
58f350guy is starting off with a positive reputation.
Lowering my 58
Hey guys I have a 58 one ton, I got it for 300 bucks. My plan is to make a cool rat rod truck out of it. I'd like to lower the truck somewhat but not get into cutting up to much. Does anyone know the easiest way to lower my truck, just take some leafs out? Or what?
  #2 (permalink)
Old 12-25-2012, 08:01 PM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Kyle Brazier
Lowering a one ton... should be interesting! I'm sure there are plenty of ways to lower a truck without hurting the wallet, but all the ways I can think of would render the truck almost useless after the mods. The ride quality would be dangerously affected, seeing as how the ride quality in an old truck like this is not the greatest in the world to begin with.
But then again, I'm not a suspension expert just some guy on a computer. Good Luck with your project! I hope it turns out good for you.
I guess the cheapest way to lower a leaf spring suspension truck like this would be to do an axle flip. This is where you move the springs from the top of the axle to the bottom of the axle. This will give you ~4" drop (or the width of the axle). If done correctly, this lowering technique can be one of the safer "cheap methods". I would look into some axle flip kits.
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
