Major Sound upgrade - Opinions - Ford Truck Enthusiasts Forums
Old 12-16-2012, 06:09 PM
Sullid01's Avatar
Sullid01 Sullid01 is offline
Sullid01 has a good reputation on FTE.Sullid01 has a good reputation on FTE.
Hi Guys,
I have a 2006 F250 CC with stock 6-changer CD/radio and speakers. I am looking to do a major upgrade and was looking for advice and opinions. I recently decided to increase my budget to about $1500. I like Pioneer so I was going to stick with them for most of the equipment. I posted this in the A/V forum but no one wanted to speak up - Is this overkill or sweet?
Here is my list so far:
Amazon.com: Pioneer AVH-P3400BH 2-DIN Multimedia DVD Receiver with 5.8" Widescreen Touch Panel Display, Built-In Bluetooth®, and HD Radio: Car Electronics
Amazon.com: Boston Acoustics Pro60 SE 6-1/2" component speaker system: Car Electronics
In the back seat I am going to just upgrade the stock speakers a bit:
Amazon.com: Pioneer TSD6802R 6 X 8 2-Way 260 Watt Speakers: Car Electronics
I am going to power this set up with:
Amazon.com: Pioneer GM-D8604 4-Channel Amplifier: Car Electronics
I am planning a single 12" sub in a sealed box from either Boxworx or Supercrew sound:
Amazon.com: Pioneer TS-SW3001S4 12-Inch Shallow Step Up S4 Subwoofer: Car Electronics
Amazon.com: Pioneer GM-D8601: Car Electronics
I am planning to run 4-0 wire to the amps and 14 guage for the speakers.
I'll use this little gizmo to hook up the steering wheel controls:
Amazon.com: Metra Axxess ASWC Universal Steering Wheel Control Interface (Black): Car Electronics
There is a good chance I'll end up paying to have it all installed since I am not sure I will be able to find the time.
I am definitely new to the car stereo world. The equipment I picked out seemed good enough. I would appreciate any thoughts or comments.
I listened to a friend's system yesterday - he has the pioneer sub in a ported box - too much rumble for me. He had the pioneer headunit and it was really nice. I doubt I will ever use the DVD bit, but a back up camera would be nice. Anyway, let me know what you all think - Thanks, Dan
__________________
Old 12-16-2012, 06:16 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
The first Upgrade here is Going to be the Alternator
I run a System and have a Couple amps (check Sig below) Nothing to Crazy
But the Problem I had was I could Eat OEM Alternators FAST
this Stereo will Kill FICM Batterys Alternators
IDK what stereo you get But I really Like the USB Drives they Have Now only 1 vehicle I have has one really like it your probably has it sounds High tech with DVD Players ect.....
Old 12-16-2012, 06:18 PM
BLADE35's Avatar
Oh do you have a Pic of the enclosed 12 inch sub box????
Old 12-16-2012, 06:20 PM
Sullid01's Avatar
I'll give some links - I have not bought anything yet.
superduty112
Ford F-250/F-350 Supercrew Cab 99-07 Dual BTS Subwoofer Box
Old 12-16-2012, 06:33 PM
Sullid01's Avatar
It has the USB - my friend's system has that and I agree it is really cool and super convenient. A DC power amp has been on the to do list for some time. Ever since I learned how to change the serp belt, I have been thinking about it
https://www.dcpowerinc.com/fit/2006~...7-300-spx.html
Old 12-16-2012, 07:04 PM
BLADE35's Avatar
Well with any stereo with Amps its Now a MUST!!!!!! the OEM Alternator can barly keep up and is really underpowered at times with stock setup
I see you looked at the 300amp SPX
These other DC Power alts are Better Built or Better parts from what I Gather
185amp
190amp (This what I run but I only run 2 amps at 1600 watts together)
250amp
270amp
Its the alt windings in the above IIRC
My 190amp does just fine
as far as the other stereo components its a Huge world the amps are not all rated the same on there Packaging been a few since I looked at them But the Higher the RMS Wattage will be the more powerful amps
The amp output needs to match the speakers maybe its the Ohms and space in Box IIRC
Its a Big world out there for stereos there are car stereo forums out there that might be good help
Mine is Far From the Best but works for me its a Mix of Pioneer MTX Sony I cant remember the Tweeters Brand but works for this Kid Far from Competiton though
Rockford Fosgate makes some the best Mono amp out there but they are spendy
Guess it depends on your Plans what you want
Old 12-16-2012, 09:23 PM
Sullid01's Avatar
I'm not looking to go too crazy, I just want some nice sound. Honestly you have more power than I need. The amps I picked are 100W RMS I think and that should be more enough. My friend's set up was way too much for me.
I remember now about the amps - the CNC billet amp just looks cool, but I remember the other being better.
Thanks for reminding me about the alternator - my friend did not do his but he has dual alts. Oh so many projects....
Did you do the install yourself?
Old 12-16-2012, 10:34 PM
BLADE35's Avatar
YES I did
these Fords are Easy Just get the Right Plug that goes factory to the New Deck Thats the only Factory wires I used but get the right plug you wont have to splice wires
You will only splice the remote Turn on for the Amps
Ran all new speaker wires to everything went big on this wires too
changed the OEM 4x6 speakers to Pioneer all 4
It had 4 tweeters in front door (2) and 2 more in the cab header panel
2 12 inch MTX subs rear truck
The rear Bench seat was Unbolted and Moved Forward to get the 12 inch subs back there
Ran some Big poweer wires to the amps off Driverside Batterys cant remember the size but its Like 3/4 inch thick power wires
But I will Strongly advise to Change the Alternator to a Preformance Alternator
I was eating Alternators in less than 5K miles
Old 12-16-2012, 11:08 PM
Sullid01's Avatar
Sounds doable, but a lot of work. I guess I would be doing similar - few less speakers. How long did it all take. Unfortunately I am short on time and long on other projects. Oil cooler is coming up...
Where did you put your amps? Under rear seat or behind it?
Old 12-16-2012, 11:42 PM
BLADE35's Avatar
I bought it used in 05 and owner B4 had a system in it so seat was done and tweeters in
1 FULL day to do that was
New Deck install with trim kit
Wire and install amps
run ALL New speaker wire
Changed all 4x6 speakers
Already had the subs in the Boxes done
Amps under rear seat
You will Love that USB drive with the amount of storage they have now Blows a 6 disc out the water plus no CD to get scratched. Any deck i get from now on will have it
Make shure the Box volume matches the Sub speakers what they require
Theres alot to a Sweet sounding system one day Im going to redo mine cause the subs are old and there Boxes are not to spec
Old 12-17-2012, 07:34 AM
Sullid01's Avatar
Thanks for all the advice - I'll see how it goes - I'll try to do as much myself as I can (have time for) - I will likely get impatient at some point. I tried to rep you but I have to spread it around some more.
My Excursion Remodel Peace2Peep Excursion - King of SUVs 148 11-19-2016 02:49 PM
Stereo upgrade 78fordman 6.0L Power Stroke Diesel 26 04-04-2015 04:18 AM
Sound system mythbustingpyro 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 10-22-2013 08:46 AM
Major Sound upgrade - Opinions Sullid01 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 12 01-12-2013 01:28 PM
About to install a head unit in my 07 Expedition -- any tips? Jason Merrick Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 4 04-02-2012 10:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
