256 Y Block water pump
Old 12-16-2012, 03:19 PM
mike2366's Avatar
mike2366
mike2366 is offline
Hi all,
Have not posted here for a while. I am still gathering up parts for my 1955 F-600 restoration.
https://www.ford-trucks.com/forums/9...d-f-600-a.html
I am in need of a hi mount water pump for a 256, not have much luck finding one.
Thanks,
Mike
Old 12-16-2012, 04:31 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
Can you get the one on the truck rebuilt? My water pump went on my '54 F-100 239 V8 years ago and you could not buy a new or rebuilt one since it is an orphan year. 55 and up are different so rebuilders don't do 54's since there isn;t much money in them. I had to send it away and wait for them to send it back...
Old 12-17-2012, 02:11 AM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
Originally Posted by mike2366
Hi all,
Thanks,
Mike
Mike,
Those are getting VERY scarce! I decided not to use mine and sold it some time ago.
Looks like I'll be able to either put the fan on the regular pump or use electric fans.....I also considered fabricating a "high-mount" fan drive using 1" rod and bearings etc.....
It would work but I just raised the engine a bit and can just use the more common pump.
If you have the old one, you should be able to get it rebuilt....I bought a new one from RockAuto a few years ago but looking now they don't even list it!
Your best bet will probably be to just rebuild the one you have.
Old 12-17-2012, 05:04 AM
mike2366's Avatar
mike2366
mike2366 is offline
Originally Posted by HT32BSX115
Mike,
Are the impeller, bearing,seal and shaft the same as a low mount pump?
Old 12-17-2012, 05:06 AM
JimG1098's Avatar
JimG1098
JimG1098 is offline
Mike2366,
I had mine refuilt by a real good place. I will give your the name and # if you want it.
It came back kike new.
off a 54 F-750 As I recal, It was not very much money and the turn arround was fast
Good luck
JimG
Old 12-17-2012, 12:29 PM
mike2366's Avatar
mike2366
mike2366 is offline
Originally Posted by JimG1098
Mike2366,
Good luck
JimG
Thanks Jim,
Could you PM it to me?
Thanks again.
Mike
dadgonebroke
08-26-2017 01:59 PM
hombre292
05-12-2016 02:05 PM
GB SISSON
13
07-15-2014 09:47 AM
grover
12-26-2005 03:10 PM
cbfomoco
12-16-2005 10:12 PM
Quick Reply: 256 Y Block water pump
