256 Y Block water pump - Ford Truck Enthusiasts Forums
Old 12-16-2012, 03:19 PM
mike2366's Avatar
mike2366 mike2366 is offline
mike2366 is starting off with a positive reputation.
Hi all,
Have not posted here for a while. I am still gathering up parts for my 1955 F-600 restoration.
http://www.ford-trucks.com/forums/91...d-f-600-a.html
I am in need of a hi mount water pump for a 256, not have much luck finding one.
Thanks,
Mike
Old 12-16-2012, 04:31 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Can you get the one on the truck rebuilt? My water pump went on my '54 F-100 239 V8 years ago and you could not buy a new or rebuilt one since it is an orphan year. 55 and up are different so rebuilders don't do 54's since there isn;t much money in them. I had to send it away and wait for them to send it back...
Old 12-17-2012, 02:11 AM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Quote:
Originally Posted by mike2366 View Post
Hi all,
Thanks,
Mike
Mike,
Those are getting VERY scarce! I decided not to use mine and sold it some time ago.
Looks like I'll be able to either put the fan on the regular pump or use electric fans.....I also considered fabricating a "high-mount" fan drive using 1" rod and bearings etc.....
It would work but I just raised the engine a bit and can just use the more common pump.
If you have the old one, you should be able to get it rebuilt....I bought a new one from RockAuto a few years ago but looking now they don't even list it!
Your best bet will probably be to just rebuild the one you have.
Old 12-17-2012, 05:04 AM
mike2366's Avatar
Quote:
Originally Posted by HT32BSX115 View Post
Mike,
Are the impeller, bearing,seal and shaft the same as a low mount pump?
Old 12-17-2012, 05:06 AM
JimG1098's Avatar
JimG1098 JimG1098 is offline
JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.
Mike2366,
I had mine refuilt by a real good place. I will give your the name and # if you want it.
It came back kike new.
off a 54 F-750 As I recal, It was not very much money and the turn arround was fast
Good luck
JimG
Old 12-17-2012, 12:29 PM
mike2366's Avatar
Quote:
Originally Posted by JimG1098 View Post
Mike2366,
Good luck
JimG
Thanks Jim,
Could you PM it to me?
Thanks again.
Mike
1955 F-600 Engine Upgrade terrister Large Truck 16 03-06-2014 12:56 PM
54 256 water pump C-700 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 2 01-21-2007 03:35 PM
256 mercury distributor Kiwi F1 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 8 01-13-2005 12:13 PM
In search of a 272 or 292 - will a 256 fit. Bessie Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 05-15-2004 11:04 AM
Will it fit? 256 in a 56' F350? Bessie 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 05-01-2004 12:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
