6.0 Oil Cooler Replacement - Ford Truck Enthusiasts Forums
Old 12-16-2012, 03:59 PM
MauleOne MauleOne is offline
MauleOne is starting off with a positive reputation.
Hey guys, I need a replacement truck (can't afford new) and am looking at a 6.0 Ford.
I hear a lot about replacing the oil cooler either with a new OEM or and complete after market change.
It seems like a critical item.
Have many of you 6.0 owners made this change?
How critical is it?
Thanks for help.
Old 12-16-2012, 04:06 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
let it go Bad and you may need engine replacement
Old 12-16-2012, 04:17 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is online now
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Bought mine with 98k.
On highway my oil temp was 15+ over coolant.
So i planned for the complete bulletproofdiesel setup. If your deltas are ok you should be ok.
Old 12-16-2012, 04:39 PM
jedlicka87's Avatar
jedlicka87 jedlicka87 is offline
jedlicka87 is starting off with a positive reputation.
Most people do and EGR delete or upgrade and are already that far into the engine so it is a good idea to replace the oil cooler at that time or vise versa. I had bought my 05 with 56k and not even having it for a month I had done a delete and new oil cooler just cuz i didnt want any problems in the near future. Did it myself with basic tools, took 2 full days taking my time making sure i didnt f**k anything up.
Old 12-16-2012, 05:37 PM
MC5C MC5C is offline
MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.
I, on the other hand, bought an '05 with 60K miles and my temps are perfect. I am adding a coolant filter soon, and don't plan any work on EGR or oil coolers in the foreseeable future. It all depends on the truck, and what the temps are. You can easily buy a Scangauge, program it and take your target truck for a drive with it plugged in.
I'd be more worried about fuel pressure, personally. I have a definite bee in my bonnet about low fuel pressure. Search blue spring...
Brian
Old 12-16-2012, 05:56 PM
jedlicka87's Avatar
Brian
I had also just put a coolant filter on from sinister. The housing they send you will have one inlet port, one outlet port (both for the coolant lines with shutoff valves) and one port has a plug in it. a FYI if you have stock headstuds like me, this makes a perfect spot to put a pressure sensor for a pod guage to keep an eye on your headgaskets.
Old 12-17-2012, 03:22 PM
Oil Cooler
Thanks for the resonses
Old 12-17-2012, 03:23 PM
Autofair Truck Parts Autofair Truck Parts is offline
Former Vendor
Autofair Truck Parts is starting off with a positive reputation.
Did you find an oil cooler yet?
Old 12-17-2012, 07:50 PM
RideDiesel88's Avatar
RideDiesel88 RideDiesel88 is offline
RideDiesel88 is gaining momentum as a positive member of FTE.
Ive had my 04 since 92k for 3yrs now at 125k. Had sgII for about a year and deltas rose to 50*! So i made the change to new oilcooler and deleted egr system. Exhaust sounds amazing when you do. The SGII definitly saved my trucks life tho. Again just a week ago it picked up low FICM volts. So i got that upgraded before i blew injectors. SGII is a must when considering this truck.
But yes, the main weak spots on the 6.0l are the Oil Coolers, EGR systems, Head Gaskets and Turbos. But they will last the life of the truck if maintained well.
Old 12-17-2012, 07:53 PM
If you think about it they all deal with each other. So its really a big system you gotta maintain.
Old 12-17-2012, 08:13 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
Preventive maintenance is a must on these beast. I bought a scangauge, flushed the crap out of it, installed a coolant filter and switch to ELC Cat 1 coolant and I monitor ECT / EOT Delta. I would not change a good oil cooler, mine is around 3 to 6 normal, and 7 to 10 towing.
For turbo, I cycle the VGT at least every week from high to low, it cycles the vane on the unisson ring and help reduce carbon and rust buildup. You floor the pedal, let the turbo go to it's max and let go the pedal, you should see you VGT cycle from the fifhtee's down to 14, if it does'nt, try again, sometimes it takes a few shots to go down to 14.
May be someone has other suggestions to cycle the turbo but it's been working for me. Before taking apart and cleaning the turbo and backflushing the oil cooler, I used to get a CEL just about every time the truck was working a bit hard. IT's been around 15,000 miles now with no light and no problem at all with this engine, I cross my finger.
Old 12-17-2012, 09:26 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
ive replaced a few hundred of them. its a 4 hour job
Old 12-17-2012, 09:37 PM
daddykitty's Avatar
daddykitty daddykitty is offline
daddykitty is gaining momentum as a positive member of FTE.daddykitty is gaining momentum as a positive member of FTE.
cheezit, what is the new oil cooler from ford with the 11th row? is that kinda like the amps from spinal tap...these go to 11
Old 12-17-2012, 10:36 PM
cheezit's Avatar
its just an updated part.
Old 12-18-2012, 12:39 PM
-Snake- -Snake- is offline
-Snake- is gaining momentum as a positive member of FTE.
To give you an idea of what's involved, here's a write up of a Bulletproof Diesel oil cooler install (pic heavy). If you're going back OEM, you can skip the BPD specific stuff.
As mentioned, there really isn't a need to replace the oil cooler unless you're seeing more than a 15* difference between ECT and EOT when driving 60-65 mph on flat ground (no trailer).
http://www.ford-trucks.com/forums/11...r-install.html
Oil cooler? olfordsnstone 6.0L Power Stroke Diesel 3 08-19-2016 06:34 PM
heater hose y-split replacement? Dgpz1100 Excursion - King of SUVs 0 04-11-2012 11:49 AM
Changing 6.0 oil cooler ajwelds 1999 to 2016 Super Duty 0 08-21-2010 02:19 PM
EGR Cooler/Oil Cooler replacement Wrapn3 6.0L Power Stroke Diesel 10 06-24-2010 08:59 PM
Oil Cooler part number... jamie7375 6.0L Power Stroke Diesel 1 01-15-2010 12:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
