Any ideas?? I am changing main engin harness along with glow plugs and plugs harness too. My question, is a lot of oil on the plug harness normal?? I have not pulled the GP's yet. This is on passenger side.
I dont think there suppost to be saturated ,but alittle oil is norm , there will be some good advise here for you Im shur after the ball games , so hang in there , also you to the tech folders and read some on oily glo plugs.
It's a 2005 with 216,000 original miles. Has been driven hard and this is reason for concern over oil on plugs, never changed before so don't know normal. Let me know if there is more info to help. Thanks
Yep GP harnes lots oil at connection and lots more on lower side of plug once pulled out. So not sure if normal or not. The harness as a whole is not soaked only pulling offof plug. hope that helps
