Dana 60 swap-or lift kit
let me see some pictures of that ride height afterwards, i was either debating f350 springs and a dana 60 for a low and level ride hieght, or doing the shackle reversal in the front and a shackle flip in the rear for a total of 4-4.5 inches of lift on top of the dana 60, havent made up my mind, the lift will cost me an extra $1000 but might be worth it.
on
1 Post
that is one good looking truck!!! i got a steal on my axle because i have done alot of work for the local junkyard so i traded them a chevy i bought for 300$ and im giving 100$ on top of that. thats for axle, steering, leaf springs, pretty much everything needed. im tearing it out tomorrow night. gonna clean it up the next few days. then throw her in starting wednsday
on
1 Post
The only difference in the 250 and 350 is the D60 axle, steering components,springs, and the 4" blocks in the rear. The springs I used in the rear are 7 leaf packs, so the truck sits about dead level now. I still need to put new bushings in the rear springs, so that might give it another 1/2".
ReBilld that is one good looking truck! im really happy i got to see those pictures because i have been trying to find another 3/4 ton with the extended cab and short bed that has done a D60 swap. exact look i want, and cheaper than the reverse shackle! Thanks man! im putting my truck on 315/75/16 Goodyear Dura tracs before i do the axle. because as my name implies i work at a tire shop... which = cheap 35s
on
1 Post
Just another suggestion.....if you have the money, go ahead and replace the spring bushings with poly ones. I used Energy Suspension bushings. Ordered them through Auto Zone for about $60 bucks for the kit to do the whole front end, shackle bushings too. They are waaayyyy better than the stock rubber bushings, and 100 times easier to change if you ever have to.
on
1 Post
Thanks. Like I said though, the pics lie LOL!! It needs a little body work and painted BAD! I like the way it sits, but I may go ahead and put the 4" 350 blocks in the rear. It has the factory Alcoa wheels back on it now with 285s. The wheels in the pic were 8" wide, so with the factory 7" wheels, it sits a little higher. I'd like to run 315s, but I'm not sure how that will affect my towing. I don't tow heavy a lot, but I do from time to time.
#29
Tempting but no thank you. i wont have another chance like this im sure in my life! haha
I got the axle out! its loaded in my truck and ready for cleaning. ill take a picture tomorrow and post it but there is BARELY grease/oil anywhere that i can see. but i have a question? i forgot about attatching the stabalizer bar. do i really need that? i know ill attatch the trac bar but i just wanna double check if i need the stabilizer
#30
-Aaron
