Is the fuel return line to the filter necessary or can I remove it?
I don't know the reason for the fuel return line which connects to the filter, but it seems to me to be asking for trouble with all the hose connections and O-rings in the return system.
I am getting air in the filter after the truck has been standing. I have replaced some O-rings, but since this is winter in Canada and I'm working outside, I am not too keen to do a complete return line overhaul if it can be avoided at this time of year.
Is the connection to the filter necessary or can it be removed?
Received 3,101 Likes
on
on
Technical Service Bulletin.
one or 2 steps below a recall notice.
it is one of those "we recommend you do it, but the world will not end if it is not done" kind of things.
back when these trucks were new, this was the recommended modification to eliminate air intrusion.
then around 93 or 94 we realized that the o-rings needed to be changed every once in a while to prevent air intrusion.
Hmm, I'm trying to picture whether that line is even there on our crate engine; IIRC, it's not.
I'm wondering about the connection from the return line to the top of the injection pump now, is that also a failed air bleed idea which can also be removed? - even with the filter full of fuel, the engine doesn't start instantly as some members describe, it takes a few seconds of cranking, so I'm wondering is air is entering there?
