Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 12-16-2012, 05:21 AM
AlmightyCrash's Avatar
AlmightyCrash AlmightyCrash is offline
AlmightyCrash is starting off with a positive reputation.
7.3l 6spd performance help?
This is my first diesel, and my first truck tbh.
2000 f250 4x4 supercab 6spd
I've been reading some to find out what easier performance mods I can do without tearing into the engine.
It seems a tuner and dpf delete are the most recommended, along with intake and exhaust.
I've settled on MBRP dual stacks (leaning toward 8"), but am not sure where to start on intake or tuners. I've considered a snorkel, but am thinking I might be tall enough to just go CAI, since I don't do the hardcore mudding I used to do in my jeep.
I think I'd like a tuner with a monitor eventually, but would be ok with a switch for now.
So everybody shoot their ideas my way so I can do this right and make my truck the best it can be.
Thanks!
Old 12-16-2012, 05:59 AM
hammer65 hammer65 is offline
hammer65 is gaining momentum as a positive member of FTE.hammer65 is gaining momentum as a positive member of FTE.
I didn't think that a 7.3 had a DPF. I may be wrong,
Old 12-16-2012, 07:44 AM
Jmatthews's Avatar
Jmatthews Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
You don't have a dpf so put your money towards some gauges, tuner, exhaust, CAI.
__________________
John
2001 7.3 F-250 LB 6sp. Dump bed, Firestone air bags, DP tuner, 4" MBRP, K&N intake with 6637, in tank mods
2002 7.3 EX limited 4x4, ccv mod, edge evo, 6637, RAS, In tank mods, diesel site tranny filter, JW valve body
Old 12-16-2012, 08:46 AM
nlemerise's Avatar
nlemerise nlemerise is online now
nlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant futurenlemerise has a brilliant future
Want the truck to last? Gauges and AE to read data. Get the truck squared away stock BEFORE throwing tuners and mods on it.
__________________
Neal
Support The Semper Fi Fund or America's Fund
Your kids are better off if you blow their college savings in Las Vegas. They'll be just as uneducated, but at least they won't be as indoctrinated. - Neal, retired professor
Old 12-16-2012, 08:51 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
It also sounds like it would be a good idea to stop talking to whoever is giving you truck advice about how to mod your truck. If they really brought up a DPF delete, then they really have no clue about what your motor needs in terms of accessories or a tuner.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 485,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
Old 12-16-2012, 10:30 AM
srteach srteach is offline
srteach is gaining momentum as a positive member of FTE.srteach is gaining momentum as a positive member of FTE.
Quote:
Good advice. A DPF first started about 2008 for Ford (IIRC). 5 years after the 7.3 was pulled from use by Ford.
The brotherhood here at FTE will not steer you wrong, but sometimes takes time to reply.
__________________
Darrell, PAA#131
The Blue(ish) Beast. 7.3 manual, 6637 Mod, Hutch mod on a steel aft axle tank, pre-pump fuel filter, coolant filter, LED rear lights, HPx, front axle rebuild, transfer case replaced, rear (clear 1 piece) window replaced with privacy manual slider
Old 12-16-2012, 10:34 AM
Thanks!
I won't take advice from them any longer.
That's why I like forums better. It's made up of people who have experience with these vehicles, and often own a very similar one.
Only thing I had to chase down was an oil leak, which was due to the filter not being fully tightened.
Everything else is great.
Only 137k on vehicle.
Old 12-16-2012, 12:06 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Not trying to justify incorrect data, but the 7.3 did come with a cat on some manuals and ca trucks. I think the guy just called it the wrong name, but, carry on.
Typically on these trucks, tearing into the motor means you're expecting done serious hp. Everything you'll do on the truck, aside from 50cent mod(which includes retorquing injectors), does not require opening up the engine.
First get the trucks fluids changed, fix leaks, and clean up grease from engine, fuel filter, check turbo, grease everything with a fitting.
Second get gauges. If you tow or go off road, or play hard, you need to know what your engine and trans is doing. You can skip the trans temp if you want and get a fuel pressure gauge, but the zf6 gets hot also and should get monitored. It should have a small cooler already, but you can buy a big side cover to let it hold more fluid.
Third
Now you can do exhaust. Get a 4" whatever. A 5" is a waste because you're not making crazy power, and the downpipe is still 4". If you didn't have a cat, you could just do a muffler delete and save a ton of money, and have same performance.
Fourth
Supporting mods for future upgrades. HPX and FRX is nice to have. (High pressure oil crossover and fuel rail crossover w/metered return to get rid of air)
It will help get oil to injectors and get rid of micro air bubbles in fuel by not allowing fuel to dead end in the number 8 injector.
Fifth
Now you can get a chip or tuner. Stick with a custom guy. The edge with its display is nice, but its harsh on equipment at times. Being a manual trans it may not be as big of an issue though.
Sixth
Now that you have all this power... Time for a clutch.
What else guys. Don't worry. Lots will chime in to help you spend your money.
__________________
JR Strout..aim UNTAMND..00psd4x4ccsbLariet37sTwinTurbo
http://www.youtube.com/profile?user=untamnd#g/u
90 F150 xlt lariat supercab 4x4 long bed 5.8 auto red interior (stock for now) 61000miles
67 Mustang GTA Fastback 390 UNTAMND.com
Old 12-16-2012, 01:40 PM
A DPF is NOT a catalytic converter. Different thing entirely.
__________________
Darrell, PAA#131
Old 12-16-2012, 02:09 PM
UNTAMND's Avatar
Quote:
We all know that, the op clearly didn't know that, and his 18 year old buddy that said dpf didn't either.
Give us a break. It like calling it a gas pedal. We know its not a gas pedal but people get it wrong all the time.
Either way, he wants to get rid of the cat, the end.
__________________
Old 12-16-2012, 03:08 PM
I'm familiar with catalytic converters, having done exhaust mods for other vehicles. The older guy behind the counter at the shop here in town brought up the DPF, which I was unfamiliar with , never having done anything diesel related. It appears, however, that my vehicle doesn't have one, so that subject is moot.
It is my understanding that the MBRP stacks get rid of the catalytic converter as part of the design, so that step will be taken care of upon installation.
I have noticed that most gauge pods have three spots.
Which three are most highly recommended?
Brand?
Digital or analog?
Old 12-16-2012, 03:44 PM
UNTAMND's Avatar
Typically
Boost
EGT
Trans temp
Later you can get
Fuel pressure
Oil temp
Boost and egt is most important. Being a manual, trans temp isn't as critical.
Maybe someone with a manual will add some info.
__________________
Old 12-16-2012, 04:30 PM
Bonanza35 Bonanza35 is offline
Bonanza35 has a very good reputation on FTE.Bonanza35 has a very good reputation on FTE.Bonanza35 has a very good reputation on FTE.
Being you have a 6spd I'd put a scan gauge in the third spot. Then you can add fuel pressure etc., to that and see it all.
Old 12-16-2012, 05:55 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel is a name known to allFat Diesel is a name known to allFat Diesel is a name known to allFat Diesel is a name known to allFat Diesel is a name known to allFat Diesel is a name known to all
I use a rotary switch with three sending units- coolant, ZF6, and diff in one standard temp gauge. But under towing/load the ZF6 will closely track coolant temp in my experience.
Old 12-16-2012, 07:16 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
I've been driving a 6spd for over 250k miles and I've had a 7.3 Excursion for over 100k miles. The following recommendations are based on my experience.
First, make sure the truck is up to par mechanically. Do all the regular maintenance including changing the fluids - specifically coolant. I recommend switching to an ELC so ya don't have to monitor SCA's and flush/change coolant periodically as is required by conventional coolant. Look for drive pressure leaks (up-pipes) and do a test to look for boost leaks. Verify glow plugs are working properly. Get hooked up to a scan tool and check things like ICP, Rotational Velocity as well as all the system switches, etc.
Next, decide what you want your end goal to be. Do you want truck that's just a lot of fun to drive on the street? Do you tow anything? Wanna do some sled pulling?? Figure out what your budget is and if you want to do the upgrades in stages, how much can you spend at a time.
After the regular maintenance and fixing the common issues, go ahead and do want ya want with the exhaust. No offense, but 8" stacks says alot about your taste... Then upgrade the air filter. The stock filter box is a POS and should be replaced. The best bang for your buck is hands-down the 6637 filter - this is good for 500HP no problem. It is louder than some of the CAI options, but performs well enough to be considered a great option.
Gauges are mandatory. EGT is by far the most critical, but I'd consider Fuel Pressure mandatory as well. Boost is good for monitoring engine performance. There is absolutely no need to monitor trans temp on a 6spd, but if ya like gauges you can make your truck look like a cockpit... I really like the Aeroforce Scangauge, since it can not only display every parameter the truck measures - it can do some of the on-board diagnostics most people go to the dealer for. This gauge gives you the EOT and coolant temp some of the others have recommended. There are 3 and 4 gauge A-pillar pods, 'cubby' pods (under dash) and over-the-mirror pods, as well as pods that go on either side of the stock dash gauges. There is also the F650 dash for a super-cool and 'stock' look...
If you are ready for more power, custom programming is where its at. I'd recommend a TS-style (6) position chip. At least one tuner offers free lifetime reburns - this is a beautiful thing if you are doing the upgrades in stages.
The only limit to how much power you can make is MONEY. A low-budget build with mild injectors and an upgraded turbo would be about $2k after the above stuff is done. For a full engine build and up to 600HP, you can easily spend well over $10k.
Eventually, you'll need a clutch for that thing. But ya likely already need a pilot bearing - since the stock offering is a total POS. A proven upgrade is to machine the flywheel to accept the larger 6.0 pilot bearing, but I've been running a roller bearing that fits the stock flywheel for awhile now with good results. For a daily driver and tow-rig clutch, ya can't beat the Southbend Con OFE (the LUK sucks by comparison). If you're gonna make big power or sled pull, you'll need something like a dual-disk clutch. When ya need to replace the hydraulics, there is an all-metal master and slave option that should be better than the plastic OE stuff - although my OE stuff has over 360K miles on it now.
Have fun and keep us posted!!!
__________________
2001 F350 CC flatbed - headstuds, AC codes, T4/S366, custom leather interior, '07 facelift, big honkin bumper, 180k miles on DIY veggie conversion and a few other things...
2000 Excursion, Limited, 4x4, BTS trans, 120k on veggie! - wrecked spring 2013 - RIP
veggiegarage.com authorized installer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
5.4 Performence and upgrades? slam1991 1997 - 2003 F150 5 03-13-2014 11:10 PM
5.4 Performence and upgrades? slam1991 Modular V8 (4.6L, 5.4L) 0 02-26-2014 10:20 PM
Best Tuner for 07 6.0L Ford11 6.0L Power Stroke Diesel 7 10-15-2013 04:12 PM
Edge Eveloution and DPF Delete Rus01 6.4L Power Stroke Diesel 5 07-13-2013 08:44 AM
New to diesel JerZee6120 6.4L Power Stroke Diesel 3 02-01-2013 07:53 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
