65 F100 352 TIMING - Ford Truck Enthusiasts Forums
65 F100 352 TIMING
Old 12-15-2012, 07:54 PM
deansbuild deansbuild is offline
deansbuild is starting off with a positive reputation.
Cool 65 F100 352 TIMING
WELL AGAIN FOR HELP? WE HAVE A 352 IN 65 F100, ALL NEW STUFF ON BLOCK, TOOK THIS IN TRADE LAST WEEK, PROBLEM IS, YOUNG MAN WHO TRADED IT, INSTALLED (RV CAM) AND WHEN IT GOT HERE, IT RUN ROUGH, BACK-FIRE & ALL. I ROLLED CAM TO TDC, 10 OFF, SET DIST TO # 1, AND IT TRYS, BUT NO GO?? ANY HELP, U GUYS KNOW LOTS, AT LEAST QUESTIONS GET ANSWERS..
Old 12-15-2012, 08:09 PM
rogue40's Avatar
rogue40 rogue40 is offline
rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.
Replace the condenser and check the point gap first. Then try setting the timing.
It's where I start when I have issues with hitting the timing.
Old 12-16-2012, 06:51 PM
ok, new problem arrived, on the 352, timing, when i set timing 10o off, and # 1 td, turn engine over 3-4 times, watching distributor turn, then check timong on crank, lining back up again, distributor off almost 180o??? does this mean timing chain or ??
Old 12-16-2012, 07:42 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
Probably not a timing chain issue. You just aren't on the compression stroke, if you turn the crank 360 degrees again the dist will be on #1.
Old 12-17-2012, 11:50 AM
ok, so, if i understand right, each time around damper, (IT Takes 2) to make a complete cycle in timing? one intake & one exhaust?? right?? OK , i'll try again, just heard so much about fiber gears & such, just about ready to tear down timing cover & check gears?? and again thanks so much for help, i been working with 300's too long, took this 352 in trade last week, still don't know if going to fix it or sell as is??? again thanks, merry Christmas also!!!!
Old 12-17-2012, 12:48 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Simple check is to remove #1 plug and place finger in hole while turning the engine and as soon as compression forces finger out, stop and check position of the rotor and timing mark, should be in ball park with rotor pointing to #1 mark on dist. to #1 plug wire and cyl., and timing mark close to TDC. Couple of cheap tune up tool I found come in handy for a quick check while under the hood is an 'inline spark plug tester', and a 'remote start button', the type where 1 lead go's to the start relay and the other lead go's to pos. side of battery. Believe dizzy rotation is 'counterclickwise' and fire order is 1-5-4-2-6-3-7-8. Not an authority, understand 4 stroke cyle consist of 2 rotations of the crank and with some ignition systems the plug will fire in the compression stroke and again in the exhaust stroke? Certain if incorrect a knowledgeable machanic will certainly let me know?
Old 12-17-2012, 02:25 PM
hiball3985's Avatar
Quote:
Correct, the cam and distributor turn at half the rotation of the crank. No fiber gears on 352's.
Old 12-17-2012, 11:11 PM
smokenchoken's Avatar
smokenchoken smokenchoken is offline
smokenchoken has a good reputation on FTE.smokenchoken has a good reputation on FTE.
i call bs on the no fiber gears i have replaced 3 of them in a short period of time they do have them........
Old 12-17-2012, 11:15 PM
hiball3985's Avatar
Quote:
My 66 didn't have one..
Old 12-18-2012, 10:40 AM
thanks so much, i was ready to scrap it, (nah not really) but at that time night, well, this trucks taking more & more time, but I love it, again, thanks to u all
352 300hp car vs 352 172hp truck sixtyfive_ford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 11-02-2016 09:48 AM
My 352 has C4AE 6090G heads, why? asmith6 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 24 08-21-2016 05:27 AM
1966 352 and trans Gcwstang 1961 - 1966 F-100 & Larger F-Series Trucks 6 05-08-2013 09:55 PM
1965 Carb for 352 F100 65F100390 1961 - 1966 F-100 & Larger F-Series Trucks 9 11-09-2010 11:22 AM
help with 352 cam and carb upgrade asmith6 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 11-13-2007 11:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
