Work cage dilemna. - Ford Truck Enthusiasts Forums
Work cage dilemna.
Old 12-15-2012, 06:06 PM
Greg5OH Greg5OH is offline
Greg5OH is starting off with a positive reputation.
Work cage dilemna.
im at the final stages for building the cage for the bed.
dont know whether to flush mount the mesh or make it ez and keep it on the outside.
outisde: stronger due to more weldable area.would pnly take 5 minutes.
flush: looks slllllick. Probably take 10 per hole so 40 mins..
wat to do?
Old 12-15-2012, 06:34 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
I welded something similar recently. I decided to split the difference. If you do it on the outer edge your welds dont look as clean. inside like your second pic would be pretty weak.
Old 12-15-2012, 06:38 PM
well, she is a dirty ugly toygh work truck, might as well keep the theme up
Old 12-15-2012, 08:51 PM
vfelix702's Avatar
vfelix702 vfelix702 is online now
vfelix702 is gaining momentum as a positive member of FTE.
Looks awesome!!!
Old 12-15-2012, 10:32 PM
86f350's Avatar
86f350 86f350 is offline
86f350 is starting off with a positive reputation.
i'd go for the stronger way, so outside
Old 12-16-2012, 01:26 AM
turtlemann14's Avatar
turtlemann14 turtlemann14 is offline
turtlemann14 is starting off with a positive reputation.
or you could recess it with some sort of backing strip and have the best of both worlds.
Old 12-16-2012, 02:22 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
i would have it at the center of the frame bar, halfway between your two pics. that gives you the full strength without the awkward rough edges on the outside where it might tear someone's clothes or whatever
if you really want the flush mount image, mount some kind of bar inside the frame to support the grating
Old 12-16-2012, 07:54 AM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
I like the last two suggestions. It looks a lot cleaner mounted inside. Maybe weld some angle or flat bar around the inside and weld the mesh to that...
Winter work and upgrades lavatan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 111 01-16-2016 02:36 PM
My crew cab swap pics dukedrummer89 1987 - 1996 F150 & Larger F-Series Trucks 39 01-06-2016 09:58 PM
no blower fan Greg5OH 1987 - 1996 F150 & Larger F-Series Trucks 2 04-13-2015 12:39 PM
I had to park next to it. (pics) Auburn_in Excursion - King of SUVs 49 01-10-2010 12:33 PM
Bumper cam (pics and video) Auburn_in Excursion - King of SUVs 15 09-01-2009 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
