Inline 6 intake manifold leak - Ford Truck Enthusiasts Forums
Old 05-24-2003, 11:57 PM
Watney Watney is offline
Watney is starting off with a positive reputation.
I have a 69 Ford Inline 6. I beleive I have an intake manifold leak. My car stalls when I come to a complete stop at the light. The service manual stated that the intake manifold was part of the cylinder head. Do I have to replace the cylinder head as well as the manifold in order to fix the leak? Are they one unit? I am too chicken to find out the "hard way!"
Old 05-26-2003, 12:49 AM
slim_falcon slim_falcon is offline
slim_falcon is starting off with a positive reputation.
take it easy slick, the manifold is attached to the head......your problem is probably just a head gasket it aint very expensive but if you remove the heads and manifold there is a certain order you have to tighten the bolts in when you put them back on so if you do it your self look into it a chilton's manual on the straight 6 bolt pattern....hope this helps....
Old 05-26-2003, 12:52 AM
Chas1234 Chas1234 is offline
Chas1234 is starting off with a positive reputation.
you have the 170 or 200 cid engine?
I think your idle is'nt set correctly or the solenoid that keeps the engine running is not adjusted correctly or not working .
Old 05-27-2003, 03:34 PM
Thumbs up Inline 6 intake manifold leak
Perfect!!! That was exactly what I nedded. Not only was there a leaking gasket, the idle screw was WAY off! Hats off to you both.
Thanks
Old 05-27-2003, 07:45 PM
glad i could help...good luck on future repairs...
Exhaust manifold??? BTFordGuy302 1987 - 1996 F150 & Larger F-Series Trucks 7 08-26-2016 04:17 PM
Head gasket gameover1974 General Automotive Discussion 0 11-26-2015 11:43 PM
FORD V8 GUY needs help with an INLINE 6 kermmydog Ranchero & 1961 - 1967 Econoline 3 10-20-2006 03:04 PM
1996 Ford Explorer Coolant leak donhclark Explorer, Sport Trac, Mountaineer & Aviator 6 05-23-2003 02:11 PM
Newer stlye exhaust manifold with older intake? roscoe Ford Inline Six, 200, 250, 4.9L / 300 2 11-17-2000 01:06 AM
Tags
1981, f150, inline, intake, manifold
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
