Is it necessary to remove the torque converter bolts when pulling an engine
Hi,
I'm in the middle of pulling the engine from my truck. I was looking through this site and came across a reference on the subject. It said that the 4 bolts holding the torque converter also need to be removed before the engine can be separated
I have removed 5 of the 6 bolts of the bell housing and am working on the 6th one. I did not remove the torque converter bolts. Is removing the torque converter bolts necessary? I'm not doubting what the other poster said, I just don't know how the tranny is held together with the engine.
My first time doing this..........
Thanks
Thanks
Hi,
After asking the question, I went out and tried to remove the bolts. The converter keeps spinning as I try and turn the nuts. I need to pull the trany anyway, so I'll remove the transfer case and pull the engine and trany together. I removed the core support to make it easier.
My next question is:
Do I have to drain the trany first before pulling it and where do I disconnect the transfer case. Should the transfer case be disconnected at the adopter close to the tranny, or the transfer case.
Thanks.
Thanks.
Hi,
Thanks.
Thanks.
Carloespo
06-28-2014 10:37 AM
deerfieldmike
12-12-2010 11:38 PM
BART M
05-17-2003 08:17 AM
