Travel Trailer Size/weight opinions
We are thinking about purchasing a travel trailer for family vacations (5 of us) and was wondering what length/weight I could look at. The tow vehicle is as follows:
E250 NA 7.3 IDI Diesel
c6/3.54 gears
Aftermarket Trans cooler added inline with stock one
trailer brake set up
I would be using a weight dist hitch and an anti sway kit. The previous owner said he towed his 7000lbs dry trailer with no issues. If this is the case I could be looking at anything up to about 30ft depending on the design/weight. I wanted to get some thought from people with experience with this. Thanks
c6/3.54 gears
Most of the newer TT's out there are fairly light so I think you will find alot of options in the wt range you are after.
Be sure to look at the data plates on the trailers you are interested. Figure 10% of gross trailer wt for what will go on the hitch.
What is your reciever rated for?
Also what kind of tires are on the van right now? You want e-rated tires.
Length is mostly a handling and manuvering issue. I agree with Bud regarding the tow ability of your truck. If you can, try to avoid ultra-light models. They are "decontented" so severely structural integrity suffers. I worked on one two days ago and unless I dropped the stabilizer jacks to support the rear end, the frame sagged so much it distorted the box and I could not open the rear door.
Steve
Steve
c6/3.54 gears
c6/3.54 gears
To senix's point, tires, class iv or preferred class v hitch with stabilizing and maybe something around 7-8k max.
I did pull a 10k 24' Ragen toy hauler with my old 99 Expy with the 5.4l motor and the tow pkg (including rear air bags that were a must) but it really wasn't well suited for that weight. One could not be in a hurry.
Better to be safe and not overdue it.
It wasn't any fun pulling something too big for my tow vehicle.
Thanks for the input. I appriciate the insight of those with experience.
Yeah, I am not looking to set any land speed records with the van, especially not when towing. I have not problem cruising in the 55-65 mph range with a trailer in tow. More worried about saftey and vehicle durability than speed. I will have to do a little research on the type of reviever it has. I know that is bolted and welded to the frame. I will double check the tires. They were brand new when I purchased the van.....I remember checking their rating at that time and they were rated as heavy duty truck tires.
I always have the option to add a cam and turbo down the road if the power bothers me.
[quote=jayro88;12604186]Thanks for the input. I appriciate the insight of those with experience.
quote]
They should start with "LT" as a light truck tire and preferrable that E- rating (10 ply) as suggested above.
quote]
Nothing that I could see easily. I will crawl under with a flashlight, but the van has been undercoated and they covered the majority of the hitch as well.
It definitly is not thin wall or small diameter square tubing.
