4.30 gears - Ford Truck Enthusiasts Forums
4.30 gears
Old 12-15-2012, 11:02 AM
cherokeexj32 cherokeexj32 is offline
cherokeexj32 is starting off with a positive reputation.
4.30 gears
Are there many Xs that came with 4.30 gears? I have been looking at many for sale trucks online and then taking the VIN to the Ford site to check the build characteristics and have not come across one yet.
Just curious....
Old 12-15-2012, 11:14 AM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Mine came with 4.30 gears. I bought it used from a used car dealer. Axle code on my sticker says C3.
Old 12-15-2012, 11:17 AM
AtomicNo13's Avatar
AtomicNo13 AtomicNo13 is offline
AtomicNo13 is gaining momentum as a positive member of FTE.
My 2001 Xlt came with 4:30 gears.
The V10 pulls my 34' Airstream as though it isn't behind me..... no downshifting except on extreme grades. Even then I can syllable drive 60 MPH. 17000 combined weight gets me 11-12, 16 empty. I am a light footed slowpoke....
Old 12-15-2012, 12:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
Syllable drive 60 MPH????
Old 12-15-2012, 01:05 PM
AtomicNo13's Avatar
Dunno what happened there.... should read "still"
Sorry for my error, I hope we can still be friends...
Old 12-15-2012, 01:40 PM
I just thought it was funny, I didn't mean to upset you...
Old 12-15-2012, 05:30 PM
Sparky04SD Sparky04SD is offline
Sparky04SD is gaining momentum as a positive member of FTE.
Front door sticker should tell you what the truck has. The sticker has a place called "axle", C3 is 4.30's. Mine came with them and many I looked at had 4.30's.
Old 12-15-2012, 08:10 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is online now
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
the 2000s did not have a code on the door sticker for the axle..why i have no clue.
i've had 3 V10 excursions and never lucked out enough to get 4:30s. every one was 3:73s
Old 12-15-2012, 08:15 PM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
It should, but not all have axle codes. Mine didn't, and without looking up the VIN and corroborating with an OASIS report from my dealer I wouldn't have found out before the purchase.
Mine has factory 4.30s as well, and I just got lucky with it. I found this out after making the deal to fly down there and buy it.
Old 12-15-2012, 08:31 PM
garryk6's Avatar
garryk6 garryk6 is offline
garryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to behold
Out of my 3 excursions, the 00 limited v10 and the 05 limited psd both have 3.73's, while the 00 XLT V10 has the 4.30's
Good luck on the search!
Just for reference, if ound out I had 4.30's by crawling under the drivers door, then looking forward at the front axle. There is a white sticker there that had the 4.30 right on the tag!
Garry in Kodiak
Old 12-15-2012, 08:52 PM
AtomicNo13's Avatar
Nah, no insult, I think life outside spellcheck can be funny!
Safe travels....
Old 12-15-2012, 09:18 PM
1 Excursion camper's Avatar
1 Excursion camper 1 Excursion camper is offline
1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of
4.30`s in an X is like a Needle in a Haystack. sounds like some of us have gotten lucky! Me, I found it easier to install the 4.30`s in my 3.73 equipped X. if you are goinf to be towing heavy then yes hold out for 4.30`s. if you are going to be towing lite, (less than 7000lbs) then 3.73`s are all you`ll need!
Good luck!
Old 01-14-2013, 09:56 PM
outlw outlw is offline
outlw is starting off with a positive reputation.
Mine has 4:30 gears bit have put all we suspension on t and then some I ave over 18500 invested including the truck. It new now with 78000 k miles I might sell t
Old 01-14-2013, 10:17 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Did the 6L come with another ratio besides 3.73?
Seems like only the V10 folks report having 4.30.
Just wondering...
Old 01-14-2013, 11:27 PM
AlaskanEx's Avatar
diesels only came with 3:73. that goes for 7.3 and 6.0.
4.30 gears and 35inch tires???? renyren 1999 - 2003 7.3L Power Stroke Diesel 16 02-21-2017 09:04 AM
Axle codes for 3.73 and 4.30 gears? bykr 6.2L V8 4 11-24-2016 02:52 PM
Anyone looking for a 2017 6.2 with 4.30 gears? PFG 6.2L V8 4 09-01-2016 12:27 AM
6.2L with 4.30s DCP 1999 to 2016 Super Duty 12 09-25-2013 05:26 PM
4.30 gears to 3.73 trucktech Excursion - King of SUVs 30 03-28-2011 11:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
