matching gears on 4x4 1959
Old 12-15-2012, 05:19 AM
mtdorf's Avatar
mtdorf
mtdorf is offline
I have always been told that the front gears are one or two teeth higher then the rear end on the older Ford pickups. I have a 1959 F100 4x4 with 4:10 gears and want to put in higher gears. Before purchasing I want to know if the front gears are higher then the rear.
Thanks in advance for your responses
Old 12-15-2012, 09:28 AM
KingBigJoe's Avatar
KingBigJoe
KingBigJoe is offline
Yes, it is true. But, it doesn't really hurt anything as long as you don't have the front axle locked & the 4x4 engaged on dry driving surfaces (pavement). Having a slightly higher [by .01 or .02] (meaning lower numbered ratio) gears in the front axle help pull the rear axle a little (helps with steering) & supposedly help prevent driveline bind a little.
Old 12-15-2012, 09:47 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
The original 59 F100 4x4 had a difference of .03 front to back, back 3.89:1 front 3.92:1.
I only point this out because you state
so you may want confirm your ratio.
Good luck in your quest.
Old 12-15-2012, 08:09 PM
mtdorf's Avatar
mtdorf
mtdorf is offline
Thanks for the info from both of you guys! I will do some checking see what I come up with for the ratio.
Thanks again.
F2501972
2009 - 2014 F150
54
02-18-2018 11:35 AM
magicsac1366
WTB - Parts & other
07-25-2012 01:48 AM
stevtalk
11-19-2006 12:51 PM
mtfl1
08-07-2002 12:00 AM
chaser
1978 - 1996 Big Bronco
02-07-2002 09:41 PM
Quick Reply: matching gears on 4x4 1959
