'56 F600 sheet metal on '56 F100 frame - Ford Truck Enthusiasts Forums
Old 12-15-2012, 05:31 AM
iforeman iforeman is offline
iforeman is starting off with a positive reputation.
Hiya all
What would I need to do to make a F600 sheet metal (Cab and front fenders,etc.) fit onto a F100 Frame. (if anything)
Thanks
Ian
Old 12-15-2012, 07:00 AM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
I honestly dont think anything. You are aware that the fenders from a F600 have a wider wheel opening though correct? Thanks
Old 12-15-2012, 09:38 AM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
All the mounting points are the same and as tacson mentioned the wheel well opening are much larger than the F-100. The rear portion of the fender sits lower than the F-100 also because the running boards are lower on a F-600 probably because the frame is 8 inches compared to the 6 inches on the F-100
Old 12-15-2012, 09:43 AM
Posting Legend
Sorry this ended up as a second try posting/ internet glitch
Old 01-31-2013, 10:51 PM
cristian75 cristian75 is offline
cristian75 is starting off with a positive reputation.
Hi there, planning to do the opposite way, put the f100 body into a modern f350 frame and will need the F600 fenders. In case you want to use the smaller f100 ones just let me know and we can trade them.
Thanks!
Old 01-31-2013, 11:00 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
You'll need a lift kit. The fender bottoms will drag the ground. Other than that, they'll bolt on.
Old 02-01-2013, 12:24 AM
POS-F500's Avatar
POS-F500 POS-F500 is offline
POS-F500 is gaining momentum as a positive member of FTE.POS-F500 is gaining momentum as a positive member of FTE.
Quote:
Thanks!
Where are you located? I have a nice pair of F500 fenders and I'd like to get a better driver's fender.
Old 02-01-2013, 07:54 AM
I'm in Miami, Fl, 33166.
Thanks!
Modern dually frame swap cristian75 1948 - 1956 F1, F100 & Larger F-Series Trucks 68 03-31-2015 07:25 PM
"Step Away From The Metal Saw" filthy6 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-18-2014 10:07 AM
1956 F600 vs F100 What's Interchangeable?? larry53deluxe 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 09-18-2013 12:53 AM
Frame dimension sheets 1956 f100 sofob0909 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-13-2013 11:19 PM
WILL DOORS AND HOOD FIT 56fordguy 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-09-2011 09:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
