Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Driveline Rear Drive Axle/Differential -- Ford 8.8-Inch Gear 2004-2011
Old 12-14-2012, 01:07 PM
Specialtools's Avatar
Specialtools
Specialtools is offline
Former Vendor
Thumbs up Driveline Rear Drive Axle/Differential -- Ford 8.8-Inch Gear 2004-2011
This is complete set includes:
303-630 Ignition Synchronizer For use on 3.8,3.9,4.2L in 99-03 Mustang and Windstar; 5.0L in 99-00 Explorer/ Mountaineer;04-07 Freestar
303-634 Socket, Rear Jack Shaft Engine -- 4.0L SOHC : Explorer ,Sport Trac,RANGER,MUSTANG : 2004-2010
303-635 Installer, Crankshaft Front Oil Seal Engine -- 4.6l;4.6L(2v),4.6L (3V),5.4L(4v)(3v);6.8L;6.8L(2v)
303-638 Alignment Gauge, Synchronizer
307-393 Installer, Pump Bearing/Fluid Seal Automatic Transaxle/Transmission -- 4F50N 2004- 2007
307-394 Remover, Pump Bearing/Seal Automatic Transaxle/Transmission -- 4F50N 2004- 2007
205-454 Runout Pin, Drive Pinion Flange Driveline System : F-250/350/450/550 Super Duty ;Excursion ;: 2004-2007
205-460 Protector, Drive Pinion Thread Driveline Rear Drive Axle/Differential -- Ford 8.8-Inch Ring Gear 2004-2011
412-130 Disconnect Tool, Heater Hose
These Tools was moved after Ford dealership closure.
$ 199.00 or best offer- "No reasonable offer will be refused!"
raybxo1@gmail.com or Please Call Ray at 512-845-4844
We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request.
I can ship Overnight or two day shipping. You decide, you are in control.( I do not ship overseas)
