Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Full Floating Axle -- Dana(50)(60)F-250/350/450/550 2004-2011
Old 12-14-2012, 12:22 PM
Specialtools's Avatar
Specialtools
Specialtools is offline
Former Vendor
Thumbs up Full Floating Axle -- Dana(50)(60)F-250/350/450/550 2004-2011
this set includes:
205-420 Remover, Wheel Hub Outer Bearing Cup (10 1/2")
205-421 Remover, Wheel Hub Inner Bearing Cup (10 1/2")
205-422 Installer, Wheel Hub Oil Seal (10 1/2")
205-423 Depth Gauge, Drive Pinion (10 1/2")
205-424 Installer, RH Differential Carrier Oil Seal (Dana 50)
205-425 Installer, LH Differential Carrier Oil Seal (Dana 50)
205-426 Installer, RH Differential Carrier Oil Seal (Dana 60)
205-427 Installer, LH Differential Carrier Oil Seal (Dana 60)
205-428 Spreader Bar, Oil Seal
205-429 Installer, Wheel Knuckle Oil Seal
205-430 Collets, Differential Carrier Bearing
205-431 Retaining Ring, Differential Carrier Bearing
205-432 Step Plate, Differential Carrier Bearing
205-433 Remover, Yoke
205-435 Installer, Differential Yoke
205-436 Installer Thread Sleeve, Yoke
205-437 Installer, Drive Nut, Yoke
205-439 Remover/Installer, Drive Pinion Oil Seal
205-440 Remover/Installer, Drive Pinion Oil Seal
205-445 Installer, Wheel Hub Inner Oil Seal
These Tools was moved after Ford dealership closure.
$ 299.00 or best offer- "No reasonable offer will be refused!"
raybx01@gmail.com or Please Call Ray at 512-845-4844
We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request.
I can ship Overnight or two day shipping. You decide, you are in control.( I do not ship overseas)
wangy
New Member Introductions
05-31-2006 04:57 AM
Quick Reply: Full Floating Axle -- Dana(50)(60)F-250/350/450/550 2004-2011
