Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-14-2012, 10:44 AM
msauls msauls is offline
1958 Ford F-100
msauls is starting off with a positive reputation.
1958 F100: confusing items under hood?
Hello, new here with a (newly acquired) '58 F100 272 Y-block.
I'm puzzled at some of the findings tho- I hope someone here can perhaps shed some light.
I found a three prong plug sticking out from under the hood and chased it to this small canister and hoses? Anyone know what this stuff is?...or what it should be?
The plug
Click the image to open in full size.
Traced back to this on the right side fenderwell. The plug wire goes into the lower portion of this small upright canister
Overall, you can see the hoses...one plugged, etc
  #2 (permalink)
Old 12-14-2012, 11:27 AM
ibuzzard's Avatar
ibuzzard ibuzzard is online now
In Memoriam.....
Garage is empty, add now
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
Welcome to FTE.
Those are the likely remains of a now-deceased cooling system warming and recirculating pump.It was installed in-line in a heater hose to prevent the engine block from freezing up.
Steve
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Entitled, self-absorbed kids - meh."
  #3 (permalink)
Old 12-14-2012, 11:53 AM
1958 Ford F-100
Thanks! So I'm assuming this is no longer needed. Should those hoses be connected to something original?
I haven't received my shop manual yet so I'm not sure what is supposed to be.
  #4 (permalink)
Old 12-14-2012, 12:07 PM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
That is an aftermarket coolant heater. It will not show up in the shop manual.
I notice that your heater core is bypassed (hose goes from water pump to engine). So you have no flow to the in cab heater. Mormally an aftermarket coolant heater is spliced into one of the lines leading to the heater. This is not needed unless tou like to have a pre heated truck on cold mornings.
  #5 (permalink)
Old 12-15-2012, 05:02 PM
1958 Ford F-100
Thanks again, Steve and 3414. All and any info is appreciated!
I'll try to get it back to normal without the aftermarket coolant heater. Truthfully I may end up omitting the heater here in TX.... But we'll see. Thanks!
  #6 (permalink)
Old 12-15-2012, 06:56 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
1960 Ford F-100
My Garage
hiball3985 is starting off with a positive reputation.
More then likely someone disconnected the heater because the core leaked.
__________________
JIM
1960 F100 Panel 223 3 spd overdrive
1966 F250 390 4 spd
1957 Ranchero 292 3 spd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
