Mechanical Fuel Pump
Old 12-15-2012, 09:23 AM
Lilryan's Avatar
Lilryan
Lilryan is offline
I was wondering if my motor had the previsions to run a mechanical fuel pump. It is a mid to late 80s block. The truck is an 87 and is carbed.
Thanks
Ryan
Old 12-15-2012, 08:08 PM
planehunter's Avatar
planehunter
planehunter is offline
If it did there would be a a plate cover over the mounting boss for the pump. This would be located on the side of the timing cover between the water pump and the block.
Old 12-15-2012, 11:38 PM
Lilryan's Avatar
Lilryan
Lilryan is offline
i will take a look tomorrow. so if it is covered with a plate, then the cam should have the lobe to run the pump?
Old 12-16-2012, 12:42 PM
big vann's Avatar
big vann
big vann is offline
No,there isn't a lobe like a Chevy has.There is a cam eccentric that needs to be bolted to the front of the camshaft.If your engine has a factory electric fuel pump then it's not likely to have the eccentric bolted on.You'll have to pull the timing cover to install one.To be sure,remove the block off plate and shine a light up towards the cam and you might be able to see it.If the engine is in the truck you'd need a small inspection camera to verify.
Old 12-16-2012, 12:50 PM
big vann's Avatar
big vann
big vann is offline
Here's a pic of the fuel pump boss.Just above the oil filter.It's shaped like a diamond.
80demoace
09-13-2007 10:32 AM
Indy_Gearhead71
02-27-2007 10:53 PM
padd54
05-29-2004 11:41 PM
willp
02-22-2003 10:23 AM
mike460
05-17-2001 09:30 AM
Quick Reply: Mechanical Fuel Pump
