i knoe the firing order on a 1997 7.3 is 12734568, but is that from side to side or front to back or what. thanks for any help i searched but only got the firing order
i am changing out the glow plugs today. i have the valve covers off and i cleaned out all the oil that is around injectors, etc. will i still have oil going down into the cylinder after i pull the plug even though i cleaned everything?
You will be fine. I hope you got motorcraft/beru glow plugs. Cheapo's like autolites will swell in the head and can cause lots of problems down the road. Like being impossible to replace without removing the head to get it out..
just left the dealership with 8 motorcraft in hand.thanks so need to turn the engine over or anything? i just hear about some people hydro locking but i think thats when they are doing injectors?
well i sucked all the oil around the plugs but it still seems like alot got into the cylinders. do i have to pull any fuses or anything before i turn over the motor to get the rest out. or should i just try to suck it out of the cylinder with the pistons at tdc?
Fuse 22. I bumped mine a few times just to be sure.
thank you. also do you know if the 97 has a exhaust back pressure tube as i do not see any tube running to the exhaust?
I'm sure it does. Front of the passenger side manifold you should see a small tube that snakes up the front of the motor that connects to the ebp sensor on top of the motor towards the front. Hopefully that makes sense.
