You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Anyone used a Flowmaster single in/dual out on your 6.2? Ifso, what series, where did you put the muffler, what size pipes did you use and do you have any drone. I'm wanting to add duals to my 2011 super duty. I would like to get my local muffler shop to do the work.
I just put a Flo on my 6.2. It's great. It's a 40 series. Not the super 40 or 44. They used a offset/offset and about 24-in of pipe in front of it. Cost me about $150 total. It is single in single out. 3-in both sides.
There is some drone up to 40-45 mph then it drops off to very little. It is not annoying at all. Installed in same location of old muffler(under the hanger)for best support. It turns a lot of heads. Especially trucks next to me.
People even want to race me?? really in a F-350 flatbed chassis cab?
Nice. How loud is it? I'm looking for a little rumble at idle and a little bark when you mash the skinny pedal, nothing real loud.
Not loud at all. You hear it at idle but it is not loud. It is loudest as you apply gas, like under acceleration. Thats where you hear a drone sound but it isnt annoying. I think you will be happy with it. I am.
I just installed this kit a couple weeks ago. The install was easy and painless, I did it on the ground without jacking, but I did have to cut the OEM exhaust just rear of the muffler to remove.
The sounds is nice and crisp, but not overbearing. It's just about right - nice rumble at idle, great sound on acceleration, and there's no drone on the highway.
Thus far I've noticed no difference whatsoever in mileage.
If you are not wanting drone, then stay away from dronemasters, I mean FlowMasters...especially a 1 in 2 out. Something with a perforated x-pipe inside is what you want to eliminate drone. My local exhaust shop carries them in stock. Also, if you choose to do 1 in 2 out, any muffler is going to have at least some drone to it. You need to eliminate the y pipe and feed 2 pipes in to muffler with 2 out to eliminate it all together. I have had duals on nearly every vehicle I have ever owned, and have had more than a few flowmaster setups. The more I learned how exhaust systems worked to change sound and flow of gases, the more I realized flowmasters are hopeless to be drone free, just by design.
__________________
2011 F250 R/C Long Bed 4x4 6.2L Tuxedo-Black, Husky Mud Flaps, Dual Mode Reverse/Auxiliary Flood Lights, Air Horn
Custom Side Exit True Dual Exhaust(Think Lightning)
Tuned by *****5 Star Tuning***** Coil On Plug Info Re: Modular Ford Engines
Hey DG, that's some rock solid advice you got there. Per our pm, I ended up removing everything back from the down tubes including that problem child collector. Now its clear why that big honkin resonator is there, just to calm done that mess of acoustics that's created by that (8 into 1) 4" collector! Good call, & thanks for your insight- I owe you one (or more)
I have a flowmaster super 40 series on mine. Its a cat-back setup. Single side exit. Honestly I don't even remember its there until I mash the pedal. But it makes a nice sound when I do. I can see it getting a bit annoying if you tow and are constantly down shifting.
