Power liftgate won't open by remote or dash button.
Hello all,
I have an 2008 Expedition EL with the power liftgate option. The lftgate only opens manually by pressing the button on the handle and lifting it open. I have read the other post where it was found that there was a low battery situation, at this time I am feeling like that is not the case. I metered the battery before start up and it read 12.54 volts, after start up it read 14.65 volts. So the battery rested all night long and retained it's charge, and when started the alternator was supplying sufficient charge. So now I am stumped. OK peanut gallery, I am open to suggestions.
OK RI-Matt. went out and checked fuse #14 on the passenger side. The fuse was not blown. Here is the funny part after I replaced fuse #14, just for giggles I tried the remote. The liftgate opened. I cycled it about 5 times to make sure i wasn't imagining anything and every time after it worked. Does that sound a little hokey to you?
So now it works ?? That's good right ??
Actually what you did by removing power to the Power liftgate module and then reappling power was you reset the module. Sometimes electronics can be quirky.
When you say you checked fuse#27 on passenger kick panel or in the engine bay ?
Matt
Matt
Fuse #27 is on the engine bay. Yeah testy testy electronics. Thanks for the help.
liftgate
I have the exact same problem. Only I removed the motor and bench tested it. The motor turned fine but the dealer said that it may not work under load.
I only did this after I checked the fuses.
Im thinking that Ill put the motor back in and replace the fuse and see if my luck is as good as yours. If not then Ill replace the motor.
tdpower
01-28-2012 01:32 PM
BK50
19
10-01-2007 10:15 AM
