MY TRUCK IS BROKE AND I CAN'T FIX IT.
Old 12-13-2012, 09:01 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Day before yesterday on my way home, my injectors started getting louder and louder. I was in 80e doing about 50 mph. I put the chip in stock and they quited down. Put it back to 80e and the injectors started getting louder while accelerating but would quieten down while steady on the pedal. I didn't feel like moving my tractor out of my shop to get the ranger out, besides I only have a 5 mile drive to work. Yesterday, 12-12-12, I notice what looked like water under my truck when I was ready to go to work. (been raining here). I put my chip in stock and away I went. When I got to work, I smelled diesel around my truck, so I looked under the truck and saw diesel leaking from the inspection plate. Told the wife I need to bring my truck home and get the ranger. When I drove into my shop, there was a solid line of diesel on the cement. When I got home yesterday evening, I opened the hood and took the plastic cover off and low and behold, there was diesel all over the place in there.
I knew it was diesel right off the bat, because it was so clean.
The reason I can't fix it right now, is because I don't have the blue o-rings to fix it. The reason I don't have the o-rings is because I used them all fixing some friends truck leaks. I need to get hold to Bob and get a few repair kits coming this way.
Make sure you guys have spare kits for this reason.
EDIT: I forgot to say the water drain valve o-rings are blown.
Old 12-13-2012, 09:28 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Well its great that you used your o rings to help someone else out but left yourself short. At least you know whats wrong and how to fix it.
Old 12-13-2012, 09:35 AM
just another truck's Avatar
just another truck
just another truck is offline
Man Rick, I am sorry to hear it..At least the Ranger is there for you..
Old 12-13-2012, 10:27 AM
Brother Les's Avatar
Brother Les
Brother Les is online now
Me thinks that you need to drive your truck more . It set up blocks for so long that the o-rings went bad in it....... . The great thing about this is that you CAN fix it and give a good warning to the Brotherhood about what can happen over time.
Just razzen ya.
Have a great and safe Christmas.
Old 12-13-2012, 10:55 AM
DISLFVR's Avatar
DISLFVR
DISLFVR is offline
Locomotive breath
Got some extra drain valve o-rings at home, can put some in the mail tomorrow if ya need 'em.
Old 12-13-2012, 11:06 AM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Bob has the complete valve for around $40 IIRC Rick, I changed out Robbys valve a month or so ago.
You can't leave a wild horse in the stable for long without consequences...
Old 12-13-2012, 11:15 AM
mueckster's Avatar
mueckster
mueckster is offline
Dang, Brother! I have set of the blue o-rings that I don't need anymore since I did the Fuel Bowl Delete. I wish I had the time to run over there. I need to come see y'all. It's been awhile.
Old 12-13-2012, 11:17 AM
Reckless's Avatar
Reckless
Reckless is offline
Yup, time to gitter-dun! Take a look at what else needs attention while in there gettin dirty.
Old 12-13-2012, 11:20 AM
Tugly's Avatar
Tugly
Tugly is offline
I have injector knock again too (driver side).... I may have to replace the injector hold-down bolts to keep them from coming loose for the 3rd time.
This now officially qualifies to fit under the heading "Sucks", right next to the "Sharp Sitck in the Eye" column.
Old 12-13-2012, 12:37 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
I hope you get everything fixed! I also have a little ranger as a spare truck and sometimes I think that Is more reliable than my excursion! It makes a great little parts fetching truck!
Old 12-13-2012, 12:46 PM
miller_feed
Thanks guys. I've been driving my truck for 2 weeks in a row.
Thanks for the offer to mail me some o-rings, but I can wait for Bob to send them. I didn't think that valve could leak that much.
Roland and I were talking about rebuilding my fuel bowl and HPOP but decided not to fix what aint broke.
Old 12-13-2012, 12:48 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
The actual breakdown is not the tragedy..his engine bay got dirty...THAT'S the tragedy..j/k Rick..
Old 12-13-2012, 12:54 PM
miller_feed
You are right. But it will be clean as soon as the valve is fixed.
Old 12-13-2012, 01:33 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Hello Rick
Was it the stock o-rings that went bad?
When mine started leaking the stockers were like plastic washers. Didn't even resemble o-rings anymore.
Old 12-13-2012, 01:51 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
that is why i have 3 sets. but then i do have 4 7.3 trucks i severs.
Quick Reply: MY TRUCK IS BROKE AND I CAN'T FIX IT.
