MY TRUCK IS BROKE AND I CAN'T FIX IT. - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-13-2012, 10:01 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Day before yesterday on my way home, my injectors started getting louder and louder. I was in 80e doing about 50 mph. I put the chip in stock and they quited down. Put it back to 80e and the injectors started getting louder while accelerating but would quieten down while steady on the pedal. I didn't feel like moving my tractor out of my shop to get the ranger out, besides I only have a 5 mile drive to work. Yesterday, 12-12-12, I notice what looked like water under my truck when I was ready to go to work. (been raining here). I put my chip in stock and away I went. When I got to work, I smelled diesel around my truck, so I looked under the truck and saw diesel leaking from the inspection plate. Told the wife I need to bring my truck home and get the ranger. When I drove into my shop, there was a solid line of diesel on the cement. When I got home yesterday evening, I opened the hood and took the plastic cover off and low and behold, there was diesel all over the place in there.
I knew it was diesel right off the bat, because it was so clean.
The reason I can't fix it right now, is because I don't have the blue o-rings to fix it. The reason I don't have the o-rings is because I used them all fixing some friends truck leaks. I need to get hold to Bob and get a few repair kits coming this way.
Make sure you guys have spare kits for this reason.
EDIT: I forgot to say the water drain valve o-rings are blown.
Old 12-13-2012, 10:28 AM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Well its great that you used your o rings to help someone else out but left yourself short. At least you know whats wrong and how to fix it.
Old 12-13-2012, 10:35 AM
just another truck's Avatar
just another truck just another truck is offline
just another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputation
Man Rick, I am sorry to hear it..At least the Ranger is there for you..
Old 12-13-2012, 11:27 AM
Brother Les's Avatar
Brother Les Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
Me thinks that you need to drive your truck more . It set up blocks for so long that the o-rings went bad in it....... . The great thing about this is that you CAN fix it and give a good warning to the Brotherhood about what can happen over time.
Just razzen ya.
Have a great and safe Christmas.
Old 12-13-2012, 11:55 AM
DISLFVR's Avatar
DISLFVR DISLFVR is offline
Locomotive breath
DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.
Got some extra drain valve o-rings at home, can put some in the mail tomorrow if ya need 'em.
Old 12-13-2012, 12:06 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Bob has the complete valve for around $40 IIRC Rick, I changed out Robbys valve a month or so ago.
You can't leave a wild horse in the stable for long without consequences...
Old 12-13-2012, 12:15 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Dang, Brother! I have set of the blue o-rings that I don't need anymore since I did the Fuel Bowl Delete. I wish I had the time to run over there. I need to come see y'all. It's been awhile.
Old 12-13-2012, 12:17 PM
Reckless's Avatar
Reckless Reckless is offline
Reckless is starting off with a positive reputation.
Yup, time to gitter-dun! Take a look at what else needs attention while in there gettin dirty.
Old 12-13-2012, 12:20 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
I have injector knock again too (driver side).... I may have to replace the injector hold-down bolts to keep them from coming loose for the 3rd time.
This now officially qualifies to fit under the heading "Sucks", right next to the "Sharp Sitck in the Eye" column.
Old 12-13-2012, 01:37 PM
Kdr358's Avatar
Kdr358 Kdr358 is online now
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
I hope you get everything fixed! I also have a little ranger as a spare truck and sometimes I think that Is more reliable than my excursion! It makes a great little parts fetching truck!
Old 12-13-2012, 01:46 PM
Thanks guys. I've been driving my truck for 2 weeks in a row.
Thanks for the offer to mail me some o-rings, but I can wait for Bob to send them. I didn't think that valve could leak that much.
Roland and I were talking about rebuilding my fuel bowl and HPOP but decided not to fix what aint broke.
Old 12-13-2012, 01:48 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
The actual breakdown is not the tragedy..his engine bay got dirty...THAT'S the tragedy..j/k Rick..
Old 12-13-2012, 01:54 PM
Quote:
You are right. But it will be clean as soon as the valve is fixed.
Old 12-13-2012, 02:33 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Hello Rick
Was it the stock o-rings that went bad?
When mine started leaking the stockers were like plastic washers. Didn't even resemble o-rings anymore.
Old 12-13-2012, 02:51 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
that is why i have 3 sets. but then i do have 4 7.3 trucks i severs.
Strange oil leak miker67 1999 - 2003 7.3L Power Stroke Diesel 4 01-06-2015 07:48 PM
fuel injector o-rings Lennyg 1997 - 2003 F150 1 02-10-2012 12:36 PM
Fuel drain valve o-rings size? Milwaukee1979F150 1999 - 2003 7.3L Power Stroke Diesel 4 01-16-2012 11:36 PM
injector issues? 884x4broncoII 1994.5 - 1997 7.3L Power Stroke Diesel 8 07-12-2010 05:29 PM
New Orings-hard to get injectors back in chris64 1994.5 - 1997 7.3L Power Stroke Diesel 19 05-21-2010 11:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
