68 pickup 3 Point Retractable Seat Belt Kit
so since i wrecked my truck, as many of u know. ive given much thought about safety. im in the process of purchasing things like disk brakes, brake booster, sway bars and a control valve for my over zelus P/S.
but what if my wife was in the truck when that blazer almost hit me? that can not happen
so my question is: is anyone using any 3 Point Retractable Seat Belt Kits for 67-72 trucks? i noticed on each side of the cab next to the rear window, there is a threaded bolt hole. was it for 3 Point Seat Belt options then?
if so what 3 Point Seat Belt Kits fit?
thanks
thanks
With optional shoulder straps, the lap seat belts were different, came with TWO buckles: One for the tongue of the shoulder strap, one for the tongue of the lap seat belt.
1977 wa the first year that one piece shoulder belts were available.
I put them in my truck last week, I got them from Seatbeltsplus.com They were very easy to install and work perfect. I also ordered the hardware kit, it's only $4.95 and well worth it. The only thing you need are the bolts for the shoulder belt hole up above your head. I went to the local salvage yard and got the bolts from a early 80's car, they are a shoulder bolt with a spacer so that the shoulder mount will swivel. My holes were not threaded but the bolts from the salvage yard were self tapping, so I put them in with the air wrench first to thread the holes, them mounted them.
Here is a link to the ones I ordered
3 Point Retractable Seat Belt With Chrome Button w/ Contoured Sleeve : Replacement Seatbelts, Seat Belts, Retractable Seat Belts, and Seatbelt Extenders @ SeatBeltsPlus.co
Here's a picture of them installed, the second one was made will my cell phone, but it give you the basic idea of the mount.
this is super-easy to do in a '68 (because of the factory mounts), and well worth it.
i wouldn't ride in a vehicle without shoulder belts- too many nutjobs on the roads these days.
let me rephrase- i wouldn't use a vehicle without shoulder belts as a daily driver.
my Galaxie doesn't have shoulder belts...yet.
pburress
01-08-2012 03:35 PM
