Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 12-12-2012, 10:42 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
NaOH shipped by mistake, what do I need to know?
Got NaOH instead of KOH by mistake (might have been mine). AAA chemical said I could send back the unused for credit. Anyway since shipping is rather steep, I though I would try a batch with it. What do I need to know beside the 1.4 conversion factor?
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 12-13-2012, 07:53 AM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
Garage is empty, add now
kirkharrod is gaining momentum as a positive member of FTE.kirkharrod is gaining momentum as a positive member of FTE.
Don't compost the glycerine. It will kill your plants.
__________________
2002 F-250 Super Cab, 289,000 miles, 89,000 on WVO; Greasecar conversion, 20 plate heat exchanger, AIH delete-water injection in its place, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, Straight Piped, GPR LED mod, CAT ELC, 203* thermostat, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, Aeroforce Interceptor scan gauge, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. No major grease related problems.
  #3 (permalink)
Old 12-13-2012, 08:07 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
And your glycerol will turn SOLID, so don't leave it too long in your processor.......
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 12-13-2012, 08:26 AM
Rushmore X's Avatar
2003 Ford Excursion
Quote:
Quote:
Both good to know, since it was going in my garden. I will go and drain the glycerol out processor today since I just ran it yesterday. I think I'll just bite the bullet and send the unused stuff back and get KOH. The stuff is less caustic anyway.
thanks again guys!
__________________
  #5 (permalink)
Old 12-13-2012, 08:30 AM
1935 Ford pickup
Hopefully the glycerol will drain.......Once the temp goes down the glycerol will get very hard.
NaOH based glycerol makes a great weed killer tho!
__________________
  #6 (permalink)
Old 12-13-2012, 08:35 AM
Rushmore X's Avatar
2003 Ford Excursion
I have a hard enough time getting stuff to grow in this drought, although the Thai Peppers did get nice and hot....
__________________
  #7 (permalink)
Old 12-13-2012, 02:04 PM
Rushmore X's Avatar
2003 Ford Excursion
How long should I let the Glycerol settle out before draining? I would let it settle at least overnight when I use KOH.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
