Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-12-2012, 06:57 PM
brucewon's Avatar
brucewon brucewon is offline
1955 Ford F-100
brucewon is starting off with a positive reputation.
Clutch Question
Hello All, I just bought a 1960 F100 with the 223 Inline 6 and the standard 3 Speed Trans.
The clutch is slipping really bad. I kept asking the PO during the test drive if he had his foot on the clutch but he didn't it's just slipping that bad.
It has a hydraulic clutch and before I go and buy a new clutch I was wondering if there is any adjustment or bleeding that might fix this issue.
Thanks in advance for your replies.
  #2 (permalink)
Old 12-12-2012, 07:55 PM
OverReved OverReved is offline
Garage is empty, add now
OverReved is starting off with a positive reputation.
I doubt it. Usually if there is a problem with hydraulic clutch setups, it's that they won't completly disengage the clutch. Just the oppsite of your problem.
  #3 (permalink)
Old 12-12-2012, 10:26 PM
brucewon's Avatar
1955 Ford F-100
That's what I was thinking too but I figured I would ask before buying a new one.
  #4 (permalink)
Old 12-13-2012, 05:05 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
The hydraulics only release the clutch and have nothing to do with the "holding part". Changing the clutch is not that big of deal and the parts are about $100.
__________________
Walston
http://bigjohnstractor.com/
  #5 (permalink)
Old 12-13-2012, 07:48 AM
HOTWRENCH HOTWRENCH is offline
HOTWRENCH is gaining momentum as a positive member of FTE.
Talking Clutch
Is there any free travel ?? If the clutch has no free travel it can slip. There is an adjustment at the slave cylinder, the rod from the slave to the throw out arm is adjustable. Make sure the throwout bearing is not in contact with the pressure plate fingers, if it is the clutch needs adjusted. If you have any Questions let me know.
Have A Great Day -------Hotwrench
__________________
FERGUSON'S GARAGE est. 1967
car , truck , heavy equiptment repairs
4 X 4 specialists PORTABLE WELDING SERVICE
TOWING New @ used PARTS
1981 L 800 460 5 speed , 2 speed rear
1957 F 600 390 5 speed
  #6 (permalink)
Old 12-13-2012, 05:10 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Yeh, to build on what HotWrench said, there is quite a bit of adjustment. Once you get down on the ground and crawl under there you will see that there is a rod with an adjusting nut and a lock nut coming out of the rear of the slave cylinder and pushing on the release lever that is protruding from the clutch housing (often referred to as bell housing).
The best thing to do is to get yourself a shop manual. It is very clear on the adjustment proceedure and repairs if needed. They can be found on ebay fairly reasonable.
  #7 (permalink)
Old 12-13-2012, 08:14 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
1960 Ford F-250
My Garage
thundersnow70 is starting off with a positive reputation.
if you do put a clutch in and decide to have the flywheel turned down you might want to mark it before you take it off. if i recall years ago when i put a clutch in my 292-4 speed i took the flywheel off and then got to spin it one bolt hole at a time till it lined up with the crank holes. NOT FUN as it weighs more than a few pounds. thats how i recall it anyway.........but it was 15 years ago. good luck
__________________
52 F2 & F3 Merryman Herringbone
60 F250 4x4
63 F250 4x4 Flareside
Mark
I might be in a cage at the zoo, but I'm still king of the jungle!
  #8 (permalink)
Old 12-17-2012, 06:20 PM
brucewon's Avatar
1955 Ford F-100
There is a lot of travel in the pedal and it engages at the very top. I suspect it needs a clutch so I ordered a new clutch kit from JCWhit's for 158.00 that includes everything.
I haven't replaced a clutch before so hopefully I won't run into any issues. If I do I will be heading here for some help for sure.
  #9 (permalink)
Old 12-18-2012, 08:43 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Call me sick, but I kind of like doing a clutch job. Maybe it's that new clutch feeling you get afterwards. Years ago, while raising a young family, all truck repairs were done in the gravel driveway. Now I'm happy to have a shop with a concrete floor. I'm hoping you won't be doing it in the snow. The fridge era trucks are about the easiest vehicles to work on. No enclosed driveline, no crazy stuff, and the 223 gives you an amazing amount of access.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #10 (permalink)
Old 12-19-2012, 06:40 PM
spurredon's Avatar
Quote:
Yeh, what he said! I must have the same sickness cause after wrestling around outside in the driveway for years and now to have a decent place to work it truly makes working on something as old as a Fridge a real treat!
  #11 (permalink)
Old 12-20-2012, 12:32 AM
GB SISSON's Avatar
The fridge trucks don't really seem all that old, but I was 4 when they came out, and tonight I'm on the road in a motel having just worked my second 12 hour day after starting out with a ferry on Monday night, driving six hours and crossing a mountain pass in blizzard conditions. I'm feeling really old. Now I know how our trucks feel......
__________________
  #12 (permalink)
Old 12-20-2012, 10:07 AM
iggy.ho iggy.ho is offline
iggy.ho is starting off with a positive reputation.
I know what you mean, I was 15 when my 59 fridge was built! I feel old and tired just reading your post!!
  #13 (permalink)
Old 01-08-2013, 02:24 PM
brucewon's Avatar
1955 Ford F-100
I finally got around to this project this last weekend and pulled everything apart to find out that I ordered the wrong clutch. I didn't realize there are two different size clutches since only one if offered at most auto parts stores. I ordered the clutch off of JCWhit which is an 11 inch clutch but after pulling mine out of the truck I quickly noticed that the new one was much bigger. I was finally able to find the right one which is actually the 10 inch clutch.
Now I can't decide if I should resurface the flywheel or not. It doesn't looked cracked it only looks like it has heat spots. I plan on putting a straight edge on it to see if its flat.
If I do decide to have the flywheel resurfaced will it drop out of the access in the clutch housing or do I need to remove that to get the flywheel off?
Luckily no snow here and plenty of concrete.
  #14 (permalink)
Old 01-08-2013, 08:13 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
1960 Ford F-100
My Garage
hiball3985 is starting off with a positive reputation.
Just my opinion but if the old clutch wasn't worn to the point of the rivets making grooves in the flywheel I wouldn't surface it. I just hit them good with a course sandpaper to knock the glaze down.
__________________
JIM
1960 F100 Panel 223 3 spd overdrive
1966 F250 390 4 spd
1957 Ranchero 292 3 spd
  #15 (permalink)
Old 01-09-2013, 09:41 AM
GB SISSON's Avatar
I use the random orbit sander from my cabinet shop. 80 grit... leaves a fine swirly pattern. Just like he said, just enough to remove the glaze.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
