2001 f-150 missfire - Ford Truck Enthusiasts Forums
2001 f-150 missfire
Old 12-12-2012, 04:14 PM
mudlife01 mudlife01 is offline
mudlife01 is starting off with a positive reputation.
2001 f-150 missfire
Hey new user I have an 01 5.4 Triton with engine light on I put it on the scanner and it read miss fire on cylinder 6 and 1 I changed the cops and plugs boots and spring erased the codes but the check light is back on and scanner is say miss fire on same two cylinders u can hear it in the exhaust u can smell gas when sitting at an idel around 40 MPH has a slight engine shake goes away when u accelerate I am not sure what else to do some one told me to check for vac leaks and fuel pressure any one have any ideals any advice greatly appreciated thanks
Old 12-12-2012, 10:34 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Maybe change the sparkplugs?
Old 12-13-2012, 06:51 AM
vaper vaper is offline
vaper is starting off with a positive reputation.
cops? did you change the spark plugs or the coils?
Swap # 6 & 1 coils to 2 other cylinders, see if the missfire's
migrate with them.
Old 12-13-2012, 12:42 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Do not keep driving the truck in this condition or you stand to burn both sides cats.
Then you will be in for more than 2 cylinders missfiring for cost and hassle.
Non firing cylinders burns gas in the cats and can melt them.
Good luck.
Old 12-15-2012, 09:42 AM
I agree Bluegrass
With 2 misfiring cylinders the CEL should of been flashing
Old 12-15-2012, 04:12 PM
Mcgiveral Mcgiveral is offline
Mcgiveral is starting off with a positive reputation.
Same issue
I had much the same issue. Changed the plugs and the problem was solved.
NO CRANK ON 08 F250 pmcgeever 1999 to 2016 Super Duty 26 02-01-2015 05:31 PM
obd 2 tester noeld Escape & Escape Hybrid 3 08-12-2014 07:48 AM
5.4 random misfire HappyRanger 1997 - 2003 F150 5 02-21-2014 02:06 AM
Misfiring too?? jimenezenrique Performance & General Engine Building 2 12-01-2013 12:10 PM
Misfiring?? jimenezenrique Modular V8 (4.6L, 5.4L) 0 11-06-2013 10:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
