Grounding the gas tank - Ford Truck Enthusiasts Forums
Old 12-12-2012, 03:23 PM
gammatino gammatino is offline
gammatino is starting off with a positive reputation.
I bought a new tank for my 92 f250. It has a hole drilled in the seem
for a ground. You supose to ground these? I think they run one in the four pin connector.
Old 12-16-2012, 12:15 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I would add a ground strap just to keep any static charge from happening.
Gas Tank Replacement Brother Hec 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-11-2016 02:12 PM
mustang gas tank sending unit/ ground? jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-23-2015 10:44 AM
97 F350 (OBS) front tank issue Jermafenser Fuel Injection, Carburetion & Fuel System 2 10-31-2014 11:27 AM
Gas sending unit & gauge TBird Larry 1961 - 1966 F-100 & Larger F-Series Trucks 11 08-22-2014 07:30 PM
stock height freakboy 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-20-2011 01:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
