PCV question - Ford Truck Enthusiasts Forums
PCV question
Old 12-12-2012, 09:36 AM
mpgo4th's Avatar
mpgo4th mpgo4th is offline
mpgo4th is starting off with a positive reputation.
PCV question
My truck is a 94 F150 5.0 auto, does this engine have the pcv behind the upper intake in the lower intake? Its where a chevrolet distributor would be. I used to mess with 5.0 mustangs back in the day and they had a PCV screen in the intake below the valve that nobody ever changed. They would get stopped up and cause oil leaks which I'm dealing with now.
Old 12-12-2012, 09:59 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Ya, pretty sure it's hooked in the lower back, real PITA to get to.
Come to think, I've had my intake a few times, but can't recall ever removing that screen and cleaning it? Lack of being able to "Breathe" and it would cause leaks everywhere.
Old 12-12-2012, 10:25 AM
mpgo4th's Avatar
its motorcraft part number FA-1068, I had Napa cross it to a wix filter and it was like 6 bucks. You can clean them but I usually messed them up getting it out. They get real stuck if no one have ever changed it. I usually have to stick a hook pick into it and pull up..
Old 12-14-2012, 10:55 AM
mpgo4th's Avatar
Update. I got a chance to look at my truck and the PVC is in the right valve cover in the back. The screen I posted is not needed on this truck.
what to use for pcv oil collector Jason302 1987 - 1996 F150 & Larger F-Series Trucks 3 09-26-2011 01:05 AM
PCV Location Exposed Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 01-22-2009 10:38 AM
pcv valve chuck7300 Explorer, Sport Trac, Mountaineer & Aviator 1 09-06-2008 03:38 PM
Need a little help relocating the PCV pipe going into 5.0 upper intake shuttlevalve 1987 - 1996 F150 & Larger F-Series Trucks 9 07-22-2008 06:55 PM
pcv valve problems mtfl1 1987 - 1996 F150 & Larger F-Series Trucks 5 11-14-2001 10:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
