F250 power steering problem
Old 12-12-2012, 01:12 AM
MyBabyCopper's Avatar
MyBabyCopper
MyBabyCopper is offline
So I just replaced my power steering box about a month ago, and it's starting to squeal every time I turn again. I heard some stuff about using ATF type f? Any tips for a beginner?
Old 12-12-2012, 02:01 AM
mark a.'s Avatar
mark a.
mark a. is offline
Are you sure you don't have a froze up axle Ujoint or something in the steering binding ?
Old 12-12-2012, 10:53 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
These boxes use type f trans fluid.
Check the pump's drive belt. Make sure its not glazed or worn. Check the belt tension, make sure its tight.
blackgate99
08-08-2013 03:47 AM
hhcobra
10-02-2011 10:22 PM
rpenterics
04-12-2006 07:25 PM
ConstantFiddler
1978 - 1996 Big Bronco
08-15-2003 09:51 PM
Quick Reply: F250 power steering problem
