Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 12-11-2012, 11:05 PM
garryk6's Avatar
garryk6 garryk6 is offline
2000 Ford Excursion
My Garage
garryk6 has a great reputation on FTE.garryk6 has a great reputation on FTE.garryk6 has a great reputation on FTE.garryk6 has a great reputation on FTE.garryk6 has a great reputation on FTE.
Boost-a-pump help needed!
I was going to the pool today and my truck started sputtering, then I smelled that awful smell of burning electrical....
This is in my 2000 Excursion with a V10 that is Whipple Supercharged. I spent a while crawling under the hood with a flashlight, and under the dash trying to find that smell. Finally I got under the truck on the ice and snow, and got a stron wiff near the frame rail, and there the "boost a pump" controller has fresh black goo running out of it... And that was definitely the source of the smell.
So... Where do I find one?
Thanks in advance!
Garry in Kodiak, Alaska
__________________
http://www.ford-trucks.com/forums/signaturepics/sigpic539273_1.gif
2002 F350 CCSB 5.4, ZF-6 4x4 "Swiss army knife of trucks"
2000 Excursion 6.8 Whipple Supercharged, 4x4 XLT,Leveled V's, Modded B's, 35x12.5x16.5 BFG AT, Harley Grill/Lights, RA Bumper, LED taillights
2000 Excursion 6.8 4x4 Limited. Stock for now...
1932 Ford "Model B" Pick-up (wtg for restoration)
  #2 (permalink)
Old 12-12-2012, 02:25 PM
garryk6's Avatar
2000 Ford Excursion
My Garage
Jeff at Whipple hooked me up with all factory drawings of the Boost-a-pump wiring for the Ford V-10, then told me exactally which wires to disconnect and the plug into different spots to place the fuel pump back in factory operation mode. Bypassing the Boost-a-pump module. Told me to drive it, but keep off the hard throttle runs till the new module gets reconnected.
KUDOS to Jeff and Whipple for great tech support and a finely engineered set-up that has built in plugs for just such emergencies!!
Hope this can help others out there!!
PS, for the Supercharger crowd...
If I want to get rid of the Boost-a-pump set up and go with a larger pump, what is involved with that process? Any body do this with the Whipple Kits?
Thanks Again!!
__________________
  #3 (permalink)
Old 12-13-2012, 12:44 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Nice to see a follow up post!
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #4 (permalink)
Old 12-14-2012, 04:36 PM
jayz66ragtop jayz66ragtop is offline
Garage is empty, add now
jayz66ragtop is starting off with a positive reputation.
Thanks Again!!
Really only have a couple of choices.
Choices
1. Boost-a-pump
2. Large enough in line pump
3. dual pumps
Honestly the for a street driven the boost-a-pump is probably the best one. The issue with options 2 and 3 are the fuel get circulated over and over since our fuel systems are a return type. So any "excess" volume just gets sent back to the tank and in the process heats up. Rinse and repeat so eventually the fuel gets hot in the tank which then flows through the pump causing it to heat up which heats the fuel even more and so on... That's why for a street driven vehicle the boost-a-pump is a good solution, as it's demand based.
This site gives a pretty good description of the different options:
Kenne Bell Boost A Pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
