Edelbrock MANUAL choke help! - Ford Truck Enthusiasts Forums
Old 12-11-2012, 09:02 PM
67FEranger's Avatar
67FEranger 67FEranger is offline
67FEranger is starting off with a positive reputation.
Question Edelbrock MANUAL choke help!
Hi guys,
Recently bought and installed a new Edelbrock Thunder AVS 650 carburator for my '67 F100 352/C4. Bought the carb to replace a leaky Holley 670 Truck Avenger. The Holley came with a Performer 390 intake that i bought about 2 years ago, but my plan was always to replace with a manual choke edelbrock AVS (Loved using the manual choke on that original 2bbl). SO installed the carburator correctly, got eveything hooked up and running GREAT. Still need to work on a few things(Ford kickdown linkage screw position, etc) One issue i have no idea about is that the manual choke does not seem to be working. First of all, the carb did not even come with an owners manual.. So had to download that. Both owners manual, and that useless cd that comes with the carb, give ZERO info on the manual choke operation..
FIRST: Yes, the choke cable is properly attached to the manual choke linkage, and does operate. However when i go to use the choke on a cold start, no action! turns over forever. So I have been starting the engine via no choke.
Now this is a summer vehicle, now parked for winter. I can still tinker with it and run it in the garage so Im open to suggestions. I AM however "carburator DEclined " I know the basics but thats it haha.
Hoping someone can give me some insight! much appretiated
Old 12-12-2012, 07:42 AM
Ohiocrewcab's Avatar
Ohiocrewcab Ohiocrewcab is offline
Ohiocrewcab is gaining momentum as a positive member of FTE.
Make sure all is tight. It has to be something simple because it is manual choke. If I was home right now I'd get a pic of my Ebrock on the truck with manual choke.
Old 12-12-2012, 12:17 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
i am guessing your choke fast idle screw is not adjusted right .
with choke full closed it should be opening your throttle plates a little bit.
Old 12-12-2012, 12:56 PM
67FEranger's Avatar
Where is the choke fast idle screw located? Carb didn't come with a manual... It's all at factory settings.
Old 12-12-2012, 04:28 PM
choke side of carb , should be an adjustment screw
Why wire open the choke? CScott422 1967 - 1972 F-100 & Larger F-Series Trucks 3 04-25-2016 01:52 AM
Choke questions answered. fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 55 07-30-2014 11:11 AM
Electric choke question 76F250High 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-13-2013 08:07 PM
Carburator Choke Issue 03trueblue 1973 - 1979 F-100 & Larger F-Series Trucks 5 09-18-2011 11:21 PM
Edelbrock 1406 Manual Choke? 66f100352 Fuel Injection, Carburetion & Fuel System 4 12-07-2009 01:12 AM
Tags
352, 4bbl, carb, choke, edelbrock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
