4.9 Distributor install TDC question
So we snapped off one of the dist cap bolts, going to get a new distributor to go along with the cap, rotor, plug wires, plugs and coil. So my question is how do you know when you are on TDC compression and not TDC exhaust. At least without taking the valve cover off or other major dismantling.
Also are we wasting money on a distributor from O'reilly's or should we get a motorcraft one.
Good luck finding a good rebuilt distributor. It's very common to get one with a pickup that dies after running a little while. These distributors all seem to be rebuilt on the cheap. I'm sure you can't buy a NEW distributor.
Only one problem here. It looks like the OP needs a distributor for a '94 with a 4.9, going by the vehicles the OP lists. Rockauto doesn't list any NEW distributors for a '94 with a 4.9.
If you know where to get a NEW distributor for a '94 with a 4.9, kindly tell the OP he may want to know.
As suggested above, the quality of "rebuilt distributors" is suspect. They should have new bearings installed along with a new PIP and gear of correct material. To the best of my knowledge, only the PIP is sold as a separate part at the retail level, so fully rebuilding your own isn't really an option. The replacement gear I've seen used on Chinese-rebuilt distributors is NOT of the same quality as OE. I'd sooner re-use an original with 200K miles.
Pull #1 spark plug, put a finger over the hole while turning the engine over in the proper direction (clockwise)until you feel air coming out of the hole. The piston is on its way up on compression at this point. Line the timing pointer up and you are on TDC of compression stroke.
Well we have not figured it out yet. The first distributor we bought said brand new only to have one of the bolt tabs break off just screwing it down. I have been letting the kid do the work as I have been busy the last few nights. Him and his friends tried for three hours yesterday with no luck. I will have to dive into it tonight. I suspect he has a plug wire or two crossed as I know we found tdc on the compression stroke. Not sure what we missing other then that as we have tried rotating the gear several teeth in both directions from we are pretty sure it should be.
To add to that we have major power steering fluid leak and the pressure line at the gear box looks like a real bugger. Good thing we have a spare vehicle cause the truck isn't going anywhere soon.
gwcrutch
07-31-2018 11:36 AM
cjben
08-04-2008 08:24 AM
Psyte
04-29-2006 06:47 AM
rsmack
08-14-2004 02:31 AM
