Power Steering Fluid Leak When Ranger Is Off - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-11-2012, 07:18 PM
EnjoyIncubus09 EnjoyIncubus09 is offline
EnjoyIncubus09 is starting off with a positive reputation.
I was pulling out of a parking lot making a sharp turn when all the sudden I lost my power steering. I have a '94 Ford Ranger manual transmission. It didn't make any sounds. I was going to try to keep adding power steering fluid to it and try to get it home to my mechanic in my hometown - but it drips constant liquid when I drive it down the street (you can see drips) so I dont think thats possible. I've read a lot on here about gear boxes failing, but would this cause it to leak even if the truck wasn't running? (the puddle builds quickly when its just sitting there, engine off). I took it to a mechanic (I don't have tools), and they said they can't say anything for sure until they look around, it could be seals which will cost 300 or a new gear box which could cost 800. What do you guys think? Thanks in advance for the help!
Old 12-11-2012, 10:13 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Why not just go see where its leaking from? It'll be the spot that is wet, with power steering fluid dripping from it.
Old 12-11-2012, 10:51 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
The pump has a rubber o-ring around it that the nylon reservoir snaps over. This is likely the cause of your leak. That being said, p/s lines and fittings rust over time and getting them apart to check the pump or replace it, often results in getting new p/s lines as well.
power steering leak Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 12-19-2016 01:05 AM
need power steering help!! goosehunta 6.0L Power Stroke Diesel 6 06-20-2014 12:28 PM
Power Steering or Gear Box? Donuts:) caliaviation Offroad & 4x4 2 01-06-2014 12:31 PM
Power steering flush - FIXED MY WANDERING Krewat 1999 to 2016 Super Duty 17 04-27-2011 11:14 AM
Old steering box works ok, but leaks like crazy. damac Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 01-23-2010 09:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
