2006 EXPEDITION 5.4 ENG PROBLEMS - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-11-2012, 05:04 PM
BRKDR BRKDR is offline
BRKDR is starting off with a positive reputation.
ENGINE HAS TAPPING SOUND LIKE STUCK LIFTER AND HAS BAD MISS AND ROUGH IDLE . WHEN DRIVING SOUNDS LIKE ITS LABORING LIKE THE OLD DAYS WHEN U USED CHEAP GAS . I PULLED THE CODES AND HERS WHAT CAME UP PO172,PO174,PO300,PO303,PO304,PO304,PO420. HAS TO BE SOMETHING CAUSING THESE CODES ANY IDEAS ON WHERE TO START WITH THIS. THANKS IN ADVANCE
help needed tomeug69 Explorer, Sport Trac, Mountaineer & Aviator 2 12-10-2015 08:48 PM
4.2 po300 Duncan Scott Millar 1968-2013 Full Size Vans 18 08-23-2015 12:22 PM
2006 Expedition 5 Error Codes JPG7 1997-2006 Expedition & Navigator 4 06-12-2015 11:28 PM
30 lbs compression on cylinder 4 Don1962 1997 - 2003 F150 6 01-16-2015 06:47 AM
Po304 po308 FFEMT32 Modular V10 (6.8l) 2 05-10-2013 07:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
