JimG 1098 build of the 54 F-750 Fire Truck - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-12-2012, 10:53 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Jim,
This is great stuff. I really enjoy the history on these trucks and I admire you guys that work so hard to preserve it.
Bobby
  #32
Old 12-13-2012, 05:54 AM
JimG1098's Avatar
JimG1098 JimG1098 is online now
JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.
Thanks Bobby
As all you guys knew before I did, It is a slow and hopefully steady pace. right now, work is a little slow, so I could actually go and work on it during the day , Also , as all of you know, it takes a lot of shop space when the thing is totally disassembled. I'll try and shoot some pics of parts hanging in various spaces in both garages
JimG
  #33
Old 12-13-2012, 07:33 AM
JimG1098's Avatar
The Brake Job
One of the first things I did was go over the brake system
Had all new lines fabricated at NAPA
Rebuilt all wheel cylinders. ( 6 ) Brake Cyl were over sised due to weight of water and tank. I could not accertain if it was done in Ford factory or Seagrave factory.
Rebuilt Master
Had brake boster rebuilt.
New frt axle seals, repacked bearings
Pulled rear axles, repacked bearings, new Diff fluid ( I believe 11 pints)
Each rear hub and drum weighed 145#. I possistioned them by placing on a funiture dolly, then putting a block under eacj leg, one at a time, untill it was of proper height. Then used wood shimms to get it the exact height of the axle. When perfect height was reached, I could simply just slide dolly forward. The hub went right in, no damage, no maring. NO STRAIN
  #34
Old 12-13-2012, 08:46 AM
bobbytnm's Avatar
Quote:
JimG
Jim,
I can hardly imagine what kind of room a big truck takes when you start tearing into it. I can barely manage with my little half ton. For us regular truck guys we have a hard time realising how big a truck like yours is. It wasn't until Keith posted a pic of his truck loaded onto a lowboy for transport that I could fully appreciate just how big of a truck it is.
It takes a special kind of crazy to rebuild a big truck, everything is big, heavy, and expensive. My hats off to you.
Bobby
  #35
Old 12-13-2012, 02:36 PM
JimG1098's Avatar
Thanks Bobby,
I'm all about the crazy (lol)
  #36
Old 12-16-2012, 09:48 AM
JimG1098's Avatar
Parts CD info
Good morning gang.
I have to replace my parts CD. For whatever reason, it got destroyed. I can't seem to find my ordering info, and like so masy of us, I DID NOT PLACE A COPY OF IT ON MY HARD DRIVE. What a moron
Anyone with that infor , please post and I will reorder a now one
I hate doing stuff twice
  #37
Old 12-16-2012, 09:56 AM
JimG1098's Avatar
Never mind
Found it HIHo parts, found it on line, Will reorder
thanks
  #38
Old 12-16-2012, 11:22 AM
bobbytnm's Avatar
Jim,
Your post made me smile. NO, I don't get enjoyment out of other peoples misery. It just makes me feel good to know that I'm not alone.
I do that sort of thing all the time
Bobby
  #39
Old 12-16-2012, 12:44 PM
JimG1098's Avatar
Yea Bobby
My middle name is Mr. ****ing Moron, lol
  #40
Old 12-16-2012, 12:49 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Yea Bobby
SINGing Moron????
  #41
Old 12-16-2012, 12:50 PM
JimG1098's Avatar
Yes, I can carry a tune in a paper bag
  #42
Old 12-16-2012, 12:52 PM
JimG1098's Avatar
Suprize coming soon
Hi gang,
Stay tuned for a little something coming in about two weeks. The excitement is building!!!
JimG
  #43
Old 12-16-2012, 12:55 PM
bobbytnm's Avatar
You big tease!!
  #44
Old 12-22-2012, 10:55 AM
JimG1098's Avatar
Leak in rear end
Hi gang,
Thinking of going after a leak in the rear end. Here is what I have.
Identified my rear, "Q" model 54 F-750 as a timken H150.
Her are som diagrams and parts breaksowns
  #45
Old 12-22-2012, 11:06 AM
JimG1098's Avatar
Rean end leak
fat fingers hit the send ugh
I have identified the leak coming from the center of part 4674, which neans to me, that the seal 4676 is bad (7EQ 4676 ). Question is this How difficult is this going to be to do, I recently put in all new gear lube- 11 pints. Can that be reused? I will need part 7EQ 4507. gasket, 7EQ 4676 seal and I dont know weather I can use 7EQ 4674 Retainer and grese seal over. Is that a solid part or is that something you would replace like a seal
Thanks, I am going to try and post actual pics of the leak
JimG
Possble pictures and posts missing from build thread JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-30-2016 05:35 PM
Water temp gauge JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 04-10-2016 12:44 AM
Happy Memorial Day and thanks for serving JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-25-2015 08:48 PM
Sometimes posting pictures are very big JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-13-2015 02:22 AM
Window crank ans door handle removal JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 09-09-2008 02:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
