Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 12-11-2012, 03:01 PM
21411 21411 is offline
1995 Ford F-350
21411 is starting off with a positive reputation.
newb thoughts
I've been lurking in this section for a while. i recently purchased a '95 F-350 7.3.
i was reading that many people are using aftermarket temp gauges to monitor the engine better. making me wonder what good the stock temp gauge is?
can it be converted to a fuel level for the second tank?
just seems silly to have a wasted gauge, when it could do some good.
also it seems every one is wrapping copper around filters and pumps and such. this seems inefficient since there is cold air and snow (potentially) splashing up and stealing this heat. what if i was to build an insulated box and include a scrap yard heater core?
just a thought.
any thoughts are welcome
  #2 (permalink)
Old 12-13-2012, 10:20 AM
1995 Ford F-350
are those 2 thoughts just crazy?
  #3 (permalink)
Old 12-13-2012, 02:03 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
I use aftermarket gauges. Can't really answer the rest of your questions, I run biodiesel myself...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #4 (permalink)
Old 12-14-2012, 11:04 AM
1995 Ford F-350
thanks for the input. I've thought about bio but i think the wife would not appreciate a processor in the garage.
maybe i'm just dreaming.
  #5 (permalink)
Old 12-14-2012, 11:37 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
Garage is empty, add now
SkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud of
I put a modified soft-sided cooler over my VO filter(s) and copper coolant wrap in winter. But, without the insulation - that is the only thing under the truck that does NOT have slush and snow on it!
Dunno about the 1rst gen PSD's, but the coolant temp gauge on my trucks is just a suggestion. No need to make it into something else, redundancy is fine... While the needle may not move between 150 and 200*, it will tell you when yer overheating. Its rare for one of these trucks to run hot though. I've had a failed fan clutch and it took pulling steep grades in 110* Arizona heat to get coolant temps over 220* - then all I had to do was take my foot out of it and it cooled down.
__________________
2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop View Post
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
  #6 (permalink)
Old 02-18-2013, 04:39 PM
F-250 Super Duty's Avatar
F-250 Super Duty F-250 Super Duty is offline
All Around Good Guy
2002 Ford F-250
F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.
Sure it can, you just need to know the ohm range of that particular gauge and have a sending unit made to match it.
I'm using my dash fuel gauge for my D2 and WVO tank levels. I had Isppro make a custom sending unit for the ohm range of the factory gauge. Tied the wiring into a relay and when D2 fuel pump is powered on it reads that tank and same for WVO fuel pump.
__________________
Mike
'02, F-250, XLT, CC, 7.3PSD, 4X4, AFE-2, 4" Exh., BTS, 6.0L Trans Cooler, 6.0 IC, 1.00 Exh. Housing, Non EBPV Pedestal, Bellowed Up-Pipes, RR Boots & Inserts, AIH Delete, HPX, 3" Lift, Hutch & Harpoon, HID's, WVO Conversion
New April 2013: Farmer's 238/100's, G2WW, 910 Springs, Pushrods, Gearhead Tunes, T500
<a href=http://i1194.photobucket.com/albums/aa371/BigRedDiesel/rsz_1img_3279.jpg target=_blank>http://i1194.photobucket.com/albums/..._1img_3279.jpg</a>
  #7 (permalink)
Old 02-18-2013, 09:18 PM
1995 Ford F-350
That is awesome, im waiting to hear back from some people about a supply so i hopefully will be spending much more time over here. I was thinking i would just moddify the existing sending unit to handle vo. Or is that a bad idea?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
