power steering/ manual steering.
ok so ive never been much for 1960s power steering. or rather power 'assist'.
i did the P/S to manual steering swop on my 67 fairlane and freakin LOVED IT!
but this is a different system on my 68 f100.
my trucks P/S is crazy sensitive which i dont like but if im pulling something then im sure its nice to have.
so my question is. with twin I-beam suspension. is it pretty difficult to steer the truck without P/Steering?
thanks
thanks
Heidts Hot Rod & Muscle Car Parts - Steering Kits & Components
If you grew up on more modern power steering, the old ones do lack some of the "feel" but if it is squirreley you probably have a problem. Toe out would be the first guess. There is also a torque sensing rod in the upper part of the power steering that needs shimmed. I have not attempted this because the shims are long gone from any parts sources I could find. Also it is a very touchy adjustment. I tried to mix and match parts once and ended up with the shimming wrong and had a box that oversteered bad in one direction.
Also those old front ends were not designed for wide tires and getting one to drive "right" with fat tires might take some experimenting with front end alignment. I generally don't like wide tires because they cut down mileage and wear out front end parts faster than normal sized ones. But that's just my 2 cents.
The only Ford trucks to use it were: 1973/75 F100 4WD / 1975 F150 4WD / 1973/77 F250 4WD (Highboys).
Originally Posted by CraigerF100
But this is a different system on my 1968 F100.
Yea that makes sense but I would still do power steering if you can. Had to go to publix when power steering was down. Of course 2 people had to wait while I did a 3 point back up to get out.
hylankyler
03-02-2015 06:01 AM
beckman
04-17-2013 11:54 PM
Caleb H
01-02-2012 10:50 PM
LoneStarTrucker
05-09-2008 06:08 PM
roy123
08-05-2007 08:31 PM
