How hard can I run my 6.0?
I have a 06 F350 with 123k. Before I bought it, it had a turbo put on, two egr's and then a oil cooler/egr cooler/vc9 flush. I bought it with an 3/36 extended warranty. After pulling my 16,000 lb fifth wheel a bit it started showing signs of a slight HG leak. Warranty paid for the head gasket r&r, and I bought ARP's to replace the TTY's. The shop also found 6 valves out of spec so they were replaced with the guides. I also had the shop install the blue spring kit while it was in for work.
I just got it back from the shop and it appears that the HG's are nice and tight now. The truck is 100% stock except for the ARP's. I almost solely use this truck to pull my camper on family trips, and I need it to be reliable. I don't plan on chipping it, but it does get run hard while pulling hills with the camper behind it.
I opted to not do the egr delete since the coolers have less than 20k on them and to preserve my ext. warranty. I do have the torque app and dongle to monitor EOT, ECT, FICM voltage, etc. I do not have an EGT pyro right now. It has Ford Gold coolant in it now, but I plan on doing a thorough flush and refill with ELC.
Questions..... how hard can I run it? Is it ok to go WOT and let the clutch fan work. Can EGT's get too high with stock programming? How much boost is too much for stock HG's and ARP's?....currently max is about 27 psi.
I have had no problems running my 350 full out when towing heavy loads. Yes it is stock. Maybe I'm just lucky, but I really believe that my experiences are typical.
Meticulous maintenance and perhaps a Scangage 2 are major factors in keeping these trucks problem-free.
Lou Braun
PS: Maintenance is really, really important.
PPS: Don't cheap out on aftermarket junk filters.
PPPS: Do all of the required maintainance items listed in the owners manual and those items mentioned in this forum.
Lou Braun
MotoCamper, you did the best thing arphead studs, get the scan gauge and keep a eye on Trans temp,EOT ECT,temps when pullin,always check Alt, Batts and Ficm Volts,as far as what to pull weight, hell Chebys and dogs just move outa way,(no afencive to International) It all depends on your Tire Rateing and short or long bed,16000 shouldent be a prob , I do 23000/24000 and theres still room .
You can't get the EGT much over 1300 with a stock tune. I have tried. You will be fine, your torque for monitoring will work great. An added EGT would be nice, but after years of staring at mine pulling hills, I have yet to see it actually go over 1300. Main thing to watch for damage causing carnage is the boost. Anything sustained over 27 or 28 is going to cause issues. It's thought that working these motors hard is actually better for it, no stuck turbo, lots of good fuel, heat, your blue spring upgrade is also good for it. I think watching the gauges is a important thing. Especially those oil and water temps, FICM volts.
Thanks for the responses!
Re:coolant filter
Do you guys still find debris in motors with high mileage that have been flushed?
Re: pyro
I have a BD X-monitor that came out of my 02, but the probe stayed with the truck. I just need to buy a new probe.
Re:boost
Is boost over 28 psi still considered unsafe when using ARP's?
Re:FICM
What is the minimum voltage that I should see?
Re:coolant filter
Re: pyro
Re:boost
Re:FICM
Yes, over 28 psi is unsafe, because you don't have the fuel capacity in those injectors and don't want more heat than stock program. For towing, you don't want to run tuned anyway, way safer on stock programming. You have a pretty large trailer, your about 6000 lbs heavier than I am so I would be interested in the pyrometer if I could.
ZRT 1000
10-30-2011 12:32 AM
