Part Number Help - EGR Tube w/DPFE 1996 F-150 4.9
Despite my best efforts, I ended up having to cut my EGR tube off so I could remove the head on my truck. I didn't want to, but it was either that or twist the tube off.
So, I need help with either a repair solution or the part number for my particular EGR tube. It isn't F5TZ-9D477-E as found on fordparts.com (even with my VIN) or Amazon. I've seen something about "California Emissions" style EGR tube and I hope that doesn't mean I can't find a new one.
My truck is a 1996 4.9 5-speed short bed, OBDII with MAF. It does have the DPFE sensor and not the EGR position sensor that bolts to the EGR valve itself.
Thank you!
Thank you!
From my 1996 Ford Parts Catalog:
F5TZ-9D477-E is F150,F250,F350 5.8L Calif w/E4OD
There are only 2 9D477's listed for the 4.9L:
F250,F350 w/C3 3 spd Trans F6TZ9D477-RA
F150,F250 w/E4OD or manual Trans F6TZ9D477-P (Includes 9P761 hoses. Orifice 7mm.) [Note: For the DPFE System]
Should be like this http://www.ebay.com/itm/F6TZ9D477P-T...item51a3f42bf4
Does is matter that the picture is for a V-8 and not the 4.9? I spoke with my local Ford Dealer (after I posted this and before your reply) and he also came up with P#F6TZ-9D477-P but his picture was also incorrect. On top of that, it showed an EGR valve that had a position sensor on it, not at all what is used in the DPFE system. He said he would get one in so we could look at it.
What are your thoughts?
And, thank you for your help!
I had thought of that, actually. Thought of a couple of different ways to make a repair work. If the part numbers that Steve came up with don't pan out, I just might have to start engineering a repair. I hope the parts work out.
Got the part in at my local Ford dealer today. Here is what it looks like:
[IMG]<a href="http://www.flickr.com/photos/yagablue/8265931228/" title="IMAG0956 by Yagablue, on Flickr"><img src="http://farm9.staticflickr.com/8057/8265931228_dc9daafa32_b.jpg" width="1024" height="577" alt="IMAG0956"></a>[/IMG]
As you can see, it looks a wee bit different than the photo, but this is the correct part. It looks like I will have to order this off of eBay through Ford-Parts-Depot (or through the other seller) as my local dealer won't go off the MSRP of $82.95, just shy of $90 with tax. I hate the fact he ordered it for me just to confirm this is the correct part, but I also can't justify spending $30-40 more than necessary. So, I'll be ordering this off eBay.
Thanks again for all of your help and suggestions and to Steve for confirming the correct P# and source locations for the part!
Yoga need your help on this one.
I need the exact same part. Can't find it anywhere. Where did you get it?
Green Sales NOS Parts
or
www.nospartsltd.com NOS Parts Ltd is an independent parts warehouse that specializes in providing Obsolete New Old Stock Ford parts for Ford and Lincoln - Mercury cars and trucks.
Otherwise, you'll have to find it off a junkyard truck. The part is specific to the 1996 4.9L
Do a search on car-part.com for a local junkyard. I'd search for "Engine" first to see who has a 1996 4.9L, then call 'em up to see if they've got the tube you need.
Last MSRP: $82.48 / Dealer net cost: $49.49.
Applications: 1996 F150/350 4.9L with E4OD or M/T (1996 F250/350 4.9L with C6 uses a different tube).
No Ford dealer or obsolete parts vendor (including Green Sales & NOS Parts Ltd) has any.
