No start - Ford Truck Enthusiasts Forums
No start
Old 12-10-2012, 02:21 PM
95Z71's Avatar
95Z71 95Z71 is offline
95Z71 is gaining momentum as a positive member of FTE.
No start
I got a problem with my truck not starting. On the first turn it starts and then immediately cuts off. Then on the second and third attemts it will not start at all. Just cranks...under the hood there seems to be a smell of fuel or plastic. Any ideas thanks.
Old 12-10-2012, 02:24 PM
bcaughhorn's Avatar
bcaughhorn bcaughhorn is offline
bcaughhorn is gaining momentum as a positive member of FTE.
any fuel leaks? how long has the fuel filter been in there?
Old 12-10-2012, 02:25 PM
95Z71's Avatar
No leaks. Fuel filter only has less than 5k
Old 12-10-2012, 02:26 PM
bcaughhorn's Avatar
any way to check fuel pressure?
Old 12-10-2012, 02:57 PM
howellt39's Avatar
howellt39 howellt39 is offline
howellt39 has a good reputation on FTE.howellt39 has a good reputation on FTE.howellt39 has a good reputation on FTE.
Do you show RPM's while cranking? What year vehicle, notable modifications, and how many miles please.
Old 12-10-2012, 03:01 PM
95Z71's Avatar
No way to check fuel pressure but I'll see about the rpms and it has 90k on it
Old 12-10-2012, 08:05 PM
95Z71's Avatar
Ok talked to cookie88 and its the gpcm. Plugged it in for 3hrs and it fired right up. How much does one run and where should I get it from? Thanks
Old 12-10-2012, 08:34 PM
95Z71's Avatar
Just noticed clay has them and will be ordering one tomorrow. Thanks for your help Scott
Old 12-10-2012, 08:36 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
I said it's probably the GPCM, but it could also be the glow plugs. You might put your scan tool on it as I think the module will set a code for bad plugs. Somebody would need to confirm that.
Old 12-10-2012, 08:51 PM
95Z71's Avatar
I read on here that some have seen the cel on when their module went out. Mine never did come on today. I will check out the scan tool tomorrow.
Old 12-11-2012, 02:35 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Well, Mike, is that a different problem then what you were having earlier, right? Sounds like it, but yes as Scott said, the GP's not getting the cylinders warm would cause it to die that soon after firing up.
BTW any issues with no starter engagement since your visit to BTS?
Old 12-13-2012, 11:24 PM
greyf350's Avatar
greyf350 greyf350 is offline
greyf350 is starting off with a positive reputation.
Sorry for the late reply. This was a different problem from my previous no start issue.
But I'm still having issues from my previous no start. They changed up some relays but the issue still exists.
Old 12-14-2012, 10:13 AM
cookie88's Avatar
Not to change the subject Mike, but what's with the new account?
Old 12-14-2012, 11:26 AM
greyf350's Avatar
Lol np. I wanted a name more suitable on the Ford forum.
Old 12-14-2012, 01:18 PM
cookie88's Avatar
I see. Did you scan the truck? Any codes? Order a GPCM yet?
HELP TRUCK WONT START Mamma Bear 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 06-09-2012 05:52 PM
starting mh5500 6.0L Power Stroke Diesel 4 08-11-2009 02:44 PM
starting problems Dkanngiesser Electrical Systems/Wiring 3 12-13-2007 07:54 PM
No start mikewalsh1 1999 - 2003 7.3L Power Stroke Diesel 2 05-10-2006 05:29 PM
truck won't start Phillip Guidry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-20-2000 08:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
