Finally! Lucille comes alive!
Got my flathead V8 back together for the third time and put back into the frame. Pulled the battery out of my service truck. Hooked up KNOWN GOOD jumper cables. Hooked up jumper wires to ignition. Racked open throttle and gave it a squirt of Brake Kleener while I connected the jumper cable to starter. Away it went with a struggle. Reached over to the distributor and gave it an arbitrary twist toward advance and tried it again. It took right off and ran solid as long as I kept feeding it fuel. Hooked up a quart container of gasoline with a piece of nylon tubing to fill the carburetor and tried it again. It took of again and ran steady and would answer the calling of the throttle. Whoo Hoo! Good oil pressure, 80 psig. Shut it off and let it cool for a few minutes and repeated the process. Same good results. I had no water in the system so I had to limit the running time to just a few seconds.
Nothing like firing an engine up after an overhaul. What a feeling of success.
on
pineconeford
20
07-06-2016 09:41 PM
82_F100_300Six
03-03-2016 12:27 PM
private-aye-fish
08-01-2006 11:26 AM
